  3. How to create text window/form with selectable text and...
  • Views 4369
How to create text window/form with selectable text and print to it
alexstepanov75
alexstepanov75 over 9 years ago
I want to create window/form and print text to it. The text should be selectable so it will be possible to copy-past from this window/form.
It seems like I can use hiCreateWindow with t_widgetType text, but i was unable to figure out how to output text to this window.
Alex.
    Alex,
    You can use hiTextDisplayString. Here's an example (bit long just for this purpose) of a dock window assistant on a text window where the buttons change based on a cyclic field, and when you press the buttons text is added in the window.
    /* abExampleDockWindow.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 15, 2012
    Modified
    By
    Not very refined example, but shows how to use a docked form window
    with a dynamic form.
    Call abExampleDockWindow() to see how this works.
    SCCS Info: @(#) abExampleDockWindow.il 11/21/12.03:04:29 1.2
    *                 abCreateExampleDynamicForm()                 *
    *  Create the form that will be docked in the window. To make  *
    *  it interesting, has some dynamic fields - as radio button   *
    *       choices are made, updates the fields on the form       *
    procedure(abCreateExampleDynamicForm()
        let((label simType magicFields staticFields)
            label=hiCreateLabel(
                ?name 'label
                ?labelText "Simulation Type:"
            simType=hiCreateRadioField(
                ?name 'simType
                ?itemsPerRow 1
                ?defValue "Dynamic"
                ?choices list("Static" "Dynamic" "Magic")
                ?callback list("abSimTypeCB(abExampleDynamicForm)")
            ; Create lists of fields (with coordinates) which will
            ; be dynamically added as radio choices are made
            magicFields=list(
                list(
                    hiCreateButton(
                        ?name 'generate
                        ?buttonText "Generate"
                        ?callback "abExampleDockAction(\"Generate Pressed\")"
                    10:120 100:30
                list(
                    hiCreateButton(
                        ?name 'run
                        ?buttonText "Run"
                        ?callback "abExampleDockAction(\"Run Pressed\")"
                    10:150 100:30
            staticFields=list(
                list(
                    hiCreateButton(
                        ?name 'delete
                        ?buttonText "Delete"
                        ?callback "abExampleDockAction(\"Delete Pressed\")"
                    10:120 100:30
            hiCreateAppForm(
                ?name 'abExampleDynamicForm
                ?formTitle "Doo dah"
                ?fields list(
                    list(label 0:0 100:30)
                    list(simType 10:30 100:120)
            ; Rather than storing the list of fields in global variables
            ; store as properties on the form
            abExampleDynamicForm->magicFields=magicFields
            abExampleDynamicForm->staticFields=staticFields
    *                  abExampleDockAction(text)                   *
    *    Callback function for the buttons - displays some text    *
    *                      in the main canvas                      *
    procedure(abExampleDockAction(text)
        hiTextDisplayString(hiGetCurrentWindow() text t)
    *                      abSimTypeCB(form)                       *
    *  Callback for the simType field - changes the fields on the  *
    *           form dependent upon the choice selected.           *
    procedure(abSimTypeCB(form)
        let((currentFields fieldsToAdd)
            ; currentFields is a property I'm using to store
            ; fields which have been dynamically added
            currentFields=form->currentFields
            when(currentFields
                hiDeleteFields(form currentFields)
            fieldsToAdd=case(form->simType->value
                ("Magic" form->magicFields)
                ("Static" form->staticFields)
            when(fieldsToAdd
                hiAddFields(form fieldsToAdd)
            ; Recompute the names of the fields which have been
            ; added (so you know what to delete next time)
            form->currentFields=
                foreach(mapcar fieldInfo fieldsToAdd car(fieldInfo)->hiFieldSym)
    *                    abExampleDockWindow()                     *
    *               Main entry point for the example               *
    procedure(abExampleDockWindow()
        let((dock swin win pulldown)
            ; Create a session (container) window plus the window itself
            swin=hiCreateWindow(nil "session" "My App")
            win=hiCreateWindow(nil "text" "My App Text")
            ; Create the form - you'd probably not do this every time if it
            ; has already been created - but this is for illustration
            ; And a dock window to contain the form
            dock=hiCreateDockWindow(
                ?appType "Example Dock"
                ?widgetType "form"
                ?handle 'exampleDock
                ?form abExampleDynamicForm
                ?title "Example Dock"
            ; Create a pulldown menu and insert into the session window
            hiCreatePulldownMenu(
                'abExampleDockWindowMenu
                "&File"
                list(
                    hiCreateMenuItem(
                        ?name 'close
                        ?itemText "&Close"
                        ?callback "hiCloseWindow(hiGetCurrentWindow())"
            hiInsertBannerMenu(
                swin
                1
            ; Dock the form, and then display the window in the session window
            hiDockWindow(
                ?window dock
                ?session swin
                ?side 'left
            hiDisplayWindow(win swin)
  • alexstepanov75
    Andrew,
    Thank you. Nice example :)
