  3. when are DRD markers refreshed?
  • Views 16438
caver456
caver456 over 8 years ago
In Virtuoso-L, DRD is a nice feature at times but because of a lot of excessive and oversimplified spacing rules hardcoded into our released tech file (which we as end-users cannot / should not change), a lot of the markers are just irrelevant clutter which mask the useful ones.  To address this, I load a drdFixes.il file, which makes transient session-only changes to the rules (using calls to techSetSpacingRule and such) via the layout trigger so it gets loaded on every open, descend-edit, and return.
So, my question is, when do the markers get refreshed / regenerated?  Can the regen / refresh be performed manually from a skill command? Understanding this would help a lot with development of the drdFixes.il file.
    Normally DRD is only triggered when you’ve done some kind of edit. However, for debugging modifications to the tech file like this, you might want to turn off DRD and then use Verify->Design which will run DRD in a batch mode (the form is labelled “Batch Checker”.
  • caver456
    I don't see 'Design' in the layout tool Verify banner menu. This is VLS-L IC6.1.7-64b.500.6. The docs point out that it's XL or GXL only. We do have one WANnable XL license somewhere, is there an L way to do the same thing or is getting the XL license the only way to go?
    The Batch Checker requires XL - if I run the SKILL function for the batch checker it says:
    *WARNING* The Batch Checker is available only in VLS XL or above license environment.
    So your choices are to either do incremental changes and test that way, or to run the batch checker from within VLS XL.
