  3. Vim settings for SKILL
  • Subscribers 152
  • Views 18223
RK56
RK56 over 9 years ago
This is for those who love vim than any other editors. I did a little bit of search and have complied the following settings for skill in vim.
Any suggestions are welcome.
1. Syntax highlighting (comes as default in VIM 7.4)
2. Dictionary setup for all SKILL keywords and procedures. (requires AutoCompletePop plugin)
3. Documentation browser (Displays the skill finder help inside vim)
TBD:
1. Tagbar integration (Configuring the tagbar plugin to display the procedure ans variables used)
2. Display the documentation help as a popup without stealing the focus.
I have the following in my ~/.vimrc
function SkillHelpLookup()
    let l:Command = expand("<cword>")
    :vert botright new
    setlocal buftype=nofile bufhidden=wipe nobuflisted noswapfile nowrap
    execute "read !sed -n '/^(\"" . l:Command . "/,/^(/p' ~/skHelp.txt | sed '$d' "
    :wincmd w
    1
endfunction
autocmd FileType skill map <F8> :call SkillHelpLookup()<CR>
autocmd FileType skill set dictionary+=~/.vim/skill_dict.txt
"------x-x-x-------
-Ramakrishnan
  • rod1
    rod1 over 4 years ago
    How did you get automatic syntax highlighting with VIM 7.4?
    I have 8.2 and when I try opening an .ocn file, I don't get any highlighting...
    Andrew Beckett over 4 years ago in reply to rod1
    If you create ~/.vim/filetype.vim and have these contents:
    " my filetype file
    if exists("did_load_filetypes")
      finish
    endif
    augroup filetypedetect
      au! BufRead,BufNewFile *.ocn  setfiletype skill
      au! BufRead,BufNewFile *.ils  setfiletype skill
      au! BufRead,BufNewFile *.sv  setfiletype verilog
    augroup END
    then it should work.
