  3. How to get the list of cells used by a Config view by using...
  • Subscribers 152
  • Views 20785
How to get the list of cells used by a Config view by using SKILL?
iguerra
iguerra over 9 years ago
I would like to know if there exists a way to get the list of cells in the "Table View" (Library, cell and view) of a Config view by skill.
Ivick.
  • mschw
    mschw over 9 years ago
    Hi Ivick,
    i think you can find the solution to your problem in the file $CDSDIR/tools/hdb/examples/hdbTraverse.il
    Best regards,
    mschw
    Actually, I don't think you need to do anything as complicated as that. Probably ccpExpandConfig would do the job. See the abNewCellViewRefs in the code below.
    /* abNewLibraryRefs.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 12, 1999
    Modified   Feb 19, 2003
    By         A.D.Beckett
    Uses the new ccpExpand facilities to expand library data,
    either using the pc.db files (parent child databases),
    or using config files to find all the cellViews or libraries
    used. This is quicker than opening databases, and also supports
    configurations.
    Each of the four functions can be used externally.
    SCCS Info: @(#) abNewLibraryRefs.il 01/03/18.17:40:58 1.3
    *    (abNewCellViewRefs libName cellName viewName @optional     *
    *              (expandMode 'CCP_EXPAND_COMANAGED))              *
    *  Expand the specified cellView, returning a list of lists of  *
    *  cellView information. The expandMode is the keyword to pass  *
    *  to ccpExpand.* functions to say what files to include. The   *
    * default should be adequate for most cases. The expansion will *
    *   follow through the complete design hierarchy, into other    *
    *  libraries, since it uses the pc.db and config information.   *
    (procedure (abNewCellViewRefs libName cellName viewName @optional
      (let (spec expanded cellViews cellViewInfo obj)
           (setq obj (ddGetObj libName cellName viewName))
           (setq spec (gdmCreateSpecFromDDID obj))
           (setq expanded
                 (cond
                  ((ddGetObj libName cellName viewName "pc.db")
                   (ccpExpandDesign spec expandMode))
                  ((ddGetObj libName cellName viewName "*.oa")
                  ((ddGetObj libName cellName viewName "expand.cfg")
                   (ccpExpandConfig spec expandMode))
                  (t
                   (setq specList (gdmCreateSpecList))
                   (gdmAddSpecToSpecList spec specList)
                   (ccpExpand specList expandMode))
           (gdmResetSpecList expanded)
           (while (setq spec (gdmNextFromSpecList expanded))
                  (when (and
                         (setq cellViewInfo (gdmInspectSpec spec "LibraryUnix"))
                         (equal (cadddr cellViewInfo) "master.tag"))
                        (rplacd (cddr cellViewInfo) nil)
                        (setq cellViews (cons cellViewInfo cellViews))
           cellViews
    *             (abNewLibraryRefs libName @optional sorted)             *
    *  Get all cellViews in a library, invoke abNewCellViewRefs on them,  *
    *     and then collate the information into a list of lists. The      *
    * optional argument is a flag to indicate that the information should *
    *                             be sorted.                              *
    (procedure (abNewLibraryRefs libName @optional sorted)
      (let (libObj cellViews cellViewTable)
           (unless
            (setq libObj (ddGetObj libName))
            (error "Could not open library %s\n" libName)
           /* create a table - easy way of removing duplicates */
           (setq cellViewTable (makeTable 'cellViewTable))
           /* visit all cells */
           (foreach cell (getq libObj cells)
                    /* visit all cellViews */
                    (foreach view (getq cell views)
                             /* get all the references, even through other libs */
                             (setq cellViews
                                   (abNewCellViewRefs
                                    libName (getq cell name) (getq view name)))
                             /* record any cellViews used in the table */
                             (foreach cellView cellViews
                                      (setarray cellViewTable cellView t))
           /* pull out everything from the table */
           (setq cellViews nil)
           (foreach cellView cellViewTable
                    (setq cellViews (cons cellView cellViews)))
           /* if sorted has been supplied and set to non-nil, sort the
              list before returning it */
           (when sorted
                 (setq cellViews
                       (sort cellViews
                             /* comparison function - sorts strings in lists */
                             (lambda (a b)
                                     (while (and
                                             (car a) (car b)
                                             (equal (car a) (car b)))
                                            (setq a (cdr a))
                                            (setq b (cdr b)))
                                     (and (car a) (car b)
                                          (alphalessp (car a) (car b)))
           cellViews
    *                      (abNewLibrariesUsed libName)                      *
    * Process the library, expand the design hierarchies and configurations, *
    *   and find out all the libraries referenced, directly or indirectly.   *
    (procedure (abNewLibrariesUsed libName)
      (let (libs)
           (foreach cellView (abNewLibraryRefs libName)
                    (unless (member (car cellView) libs)
                            (setq libs (cons (car cellView) libs))))
           libs
    *         (abNewLibrariesUsedByCellView libName cellName viewName)          *
    * Process the cellView, expanding the hierarchy, and find out all libraries *
    *                    referenced, directly or indirectly.                    *
    (procedure (abNewLibrariesUsedByCellView libName cellName viewName)
      (let (libs)
           (foreach cellView (abNewCellViewRefs libName cellName viewName)
           libs
  • iguerra
    Hi mschw and Andrew,
    Since it was urgent, I used the hdbTraverse.il but I had to add code for creating a list without duplicated Masters.
    By now I don't have more time to test the abNewCellViewRefs function but anyways I will keep it in mind for any future development.
    Thanks.
