  3. How to catch empty stringfield in SKILL gui ?
  • Subscribers 148
  • Views 17106
Marben
Marben over 8 years ago
Hi All,
How to catch empty stringfield in gui using SKILL ?
For example, if the user forgot to fill the string field and he click
the apply button, message in the CIW should be, "Stringfield is empty,
please input something ."
Thanks in advance.
Best regards,
Marben
  • skillUser
    skillUser over 8 years ago
    Hi Marben,
    There is a built-in predicate function for checking if a string is blank/empty or not: blankstrp()
    You can use it directly on the form field, e.g.
    if(blankstrp(myform->myStrField->value) then
      warn("String myStrField is empty, please check and try again\n") ;; issue a warning message
      hiHighlightField(myform 'myStrField 'error) ;; hilight the string field
      hiSetCallbackStatus(myForm nil) ;; prevent the form from unmapping from the screen
    else
      hiHighlightField(myform 'myStrField 'background)
      ;; do the desired form action...
    The above was not tested directly (so beware of any typos) but it is the sort of flow that I have used in the past.
    Best regards,
    Lawrence.
  • Marben
    Hi Lawrence,
    Your code works like a charm.
    Thank you very much.
    Best regards,
    Marben
