  3. accessing leWeChooseLayerForm
  • Subscribers 148
  • Views 16109
RK56
RK56 over 8 years ago
Hi Guys,
Is there any way to include leWeChooseLayerForm in our custom scripts? I want the user to pick a LPP when the user clicks a point in the layout canvas. I can write the skill function for this but I came across leWeChooseLayerForm.
Is there any inbuilt function to access this LPPform?
-Ramakrishnan
    Hi Ramakrishnan,
    I wouldn’t do that (I’m not sure which version you’re using - but I’m not sure that form is necessarily guaranteed to exist, nor exists in all versions).
    One approach would be to call leHiLayerTap() - this will prompt you if there’s ambiguity of the layer where you click, and then set the current layer (retrievable with leGetEntryLayer() ) to be whatever you choose.
  • RK56
    Thanks Andrew for the response. How do I call leHiLayerTap() on a specific point? Is there anything like leLayerTap(?pt enterPoint())
    In the end I need to save both the point and LPP
    -Ramakrishnan
    Ramakrishnan,
    Yes. Use preXY(thePoint) before calling leHiLayerTap(). For example:
    point=enterPoint()
    preXY(point)
    leHiLayerTap()
  • RK56
    Thanks Andrew. preXY() is something new that I learnt here.
