  3. Possible or not to highlight text in UI?
  • Views 16381
Keii
Keii over 8 years ago
Hello All,
A little background about my question.
A co-worker has helped with creating a special MV script which has a UI that allows me to enter (x,y) coordinates to move the selected object by whatever I input. The only thing I don't like about it is that when I execute the command I have to first delete the default value (0,0) in the UI. For now I have created a macro on my gaming mouse that does a Ctrl+A then executes the special MV command, but I would like anyone to be able to use this.
The question:
I don't know if this would be simple or not, but is there a way to have the value highlighted as soon as the UI pops up so that I can immediately type the coordinates?
Here is the script:
moveToXYValue = list(0 0)
procedure(moveToXY()
let(()
pointsField = hiCreatePointField(
                ?name 'pointsField
                ?prompt "Enter Point"
                ?value moveToXYValue
form=hiCreateAppForm(
        ?name 'form
        ?fields list( list(pointsField 0:0 200:20 100))
        ?callback 'moveCallback
hiDisplayForm(form)
procedure(moveCallback(one)
let(()
        xy = one->pointsField->value
        moveToXYValue=xy
        ;leZoomToPoint(geGetEditCellViewWindow(geGetEditCellView()) xy )
        mv(car(xy) nth(1 xy))
hiSetBindKey("Layout" "<key>m" "moveToXY()")
procedure(mv(@optional dx dy)
let((fig cv)
        if((dx== nil || dy == nil) then
                println("mv : Moves the selected element by x and y")
                println("USAGE: mv(x_move y_move)")
        else
                foreach(fig geGetSelectedSet()
                        if(fig~>objType != "textDisplay" &&  fig~>objType != "label"  then
                                println(fig~>objType)
                                cv =fig~>cellView
                                if(geIsFigPartiallySelected(fig) then
                                        leStretchShape(fig dx:dy geGetSelSetFigPoint(fig))
                                else
                                        dbMoveFig(fig cv list(dx:dy "R0"))
                                );if
                        );if
                );foreach
        );if
        nil
);let
);provedure mv
Keith
  • skillUser
    skillUser over 8 years ago
    Hi Keith,
    I think that you can just build the field with no default value (empty) and since it is the only field on the form, I think it already has focus, but you may need to move the mouse over the form, depending on your window manager.  Here's the modified code:
      let((pointsField form)
    	    ?name 'pointsField
    ;;	    ?value moveToXYValue
    	    ?name 'moveToXYForm
    	    ?formTitle "Move To XY"
        hiDisplayForm(form)
    Try it out.  Good luck.
    Lawrence.
  • Keii
    Thanks Lawrence, I forgot to mention a portion of the script (the part that you removed) was to remember the last value entered. You are right, if I didn't have the memory part of the script then it would work for what I asked. The second part of the script that redefines the "mv" function is there so if I partially select an object it does a "stretch" command instead of a "mv".
  • skillUser
    Hi Keith,
    Ok, for that to work (automatically) don't redefine the form each time:
        if(boundp('moveToXYForm) && hiIsForm(moveToXYForm) then
          form = moveToXYForm
        else
    	    ?name 'pointsField
    	    ?name 'moveToXYForm
        ); if
        hiDisplayForm(form)
      ); let
    ); procedure moveToXY
    Best regards,
    Lawrence.
  • Keii
    skillUser said:
    Hi Keith,
          form = moveToXYForm
        else
    	    ?name 'pointsField
    	    ?name 'moveToXYForm
        ); if
        hiDisplayForm(form)
      ); let
    Best regards,
    Lawrence.
    This worked exactly the way I needed it to! Thank so much Lawrence!
    -Keith
