  3. generate spectre subckt netlist from cellview?
  • Views 17523
drdanmc
drdanmc over 8 years ago
Is there an easy way to generate a spectre netlist in subcircuit form from a schematic or av_extracted cellview?  In the past I've done things like call virtuoso with a replay file that has something like:
envSetVal("asimenv.startup" "projectDir" 'string "my_netlist_directory")
simulator('spectre)
design("myLib" "myCell" "myView")
createNetlit(?recreateAll t)
this has been most useful, but of course this gives me the netlist of myCell as the top of the netlist.  I have a  need to create subcircuits, i.e.
subckt myCell p1 p2 p2 ...
// netlist contents
ends myCell
as opposed to just the netlist contents.  It would be nice if any CDF parameters ended up in the header properly.
I could do this by creating a new schematic and instantiating myCell into it and then netlisting this wrapper schematic and then using awk/perl/python/whatever to pull out what is between the subckt/ends lines (inclusive) but that requires either manual intervention (creating the wrapper schematic) or at least a writable library which I may or may not have.
Think custom cells -> subckt -> liberate for characterization for one reason this could be needed.
Any suggestions?
-Dan
    Hi Dan,
    This can be done quite simply - all you need to do is add:
    envOption( 'setTopLevelAsSubckt  t )
    before the call to createNetlist() (after the design() call, probably).
    This corresponds to the same option which is on Setup->Environment in ADE. This has been in ADE for some time, but unless  you’d spotted it appearing, the chances are you’d never have noticed!
  • drdanmc
    Clearly I'm due to go through the ADE forms again! Works like a champ and yes, I put it after the design() call.
    Much appreciated.
    -Dan
