  3. How to create placement blockage in desired area?
  • Views 19672
Vishhh
Vishhh over 8 years ago
dbCreateLayerBlockage(..)   --> command works to create blockage of type 'routing' and etc..  But it isn't working for placement - type.
Looks like the command doesn't support placement blockage.
Is there any other way how to create the blockage of type placement?  ( Hard - placement ).
Will be very helpful if any of you can provide me the command.
Kind Regards,
Vish
  • skillUser
    skillUser over 8 years ago
    Hi Vish,
    From the documentation (SKILL Finder, I typed "blockage" to get all the matches):
    dbCreateAreaBlockage( d_cellviewId l_points [ d_owner ] )
    => d_areaBlockageId / nil
    Creates an area blockage object of the type placement in the given cellview. Area blockages are used to prevent instances from being placed within a specific area.
    I think this is what you are looking for.
    Best regards,
    Lawrence.
  • Vishhh
    Yes this worked. Thanks for the help Lawrence and Andrew! :)
    Vish
