  3. How to apply "ocnYvsYplot" API to a family of waveforms
  • Subscribers 150
  • Views 2586
fatcat1206
fatcat1206 over 8 years ago
Hi All
Does someone know how to apply "ocnYvsYplot" API to a family of waveforms.
According to the API manual, "ocnYvsYplot" is not supported for a family of waveforms.
But I want to use it in the ADEXL, even with the single norminal run, the final simulation data will consider it's a family waveforms.
I have tried "famMap" function, but do not know how to deal with the "Key" type argument.
Best Regards
Yi
    Yi,
    You should use the waveVsWave function instead.
  • fatcat1206
    Hi Andrew
    Thank you so much.
    It works
    Best Regards
    Yi
  • drdanmc
    drdanmc over 8 years ago
    As Andrew said, use waveVsWave. If you find that you need to use famMap in the future with a function that has keyword arguments, you should be able to do something like:
    procedure( myFn( sig @key (key1 def1) (key2 def2) ... )
    if(famIsFamily(sig) then
    famMap( 'myFn sig ?key1 key1val ?key2 key2val ...)
    else
    ;; code for a single waveform
    note that this is assuming sig is a waveform or waveform family and the other args are not families.
    -Dan
    Hi Dan,
    I think it should “unwrap” any of the remaining arguments if they are families too - not just the first. I didn’t test it with ?key arguments (it certainly does that with non-key arguments) but having a quick glance at the code, I think it should work for all arguments.
  • fatcat1206
    Hi Dan
    Thank you for your hint.
    I have tried the similar approach for the "ocnYvsYplot", it does not succeed.
    Now I realize that the why it fails.
    As shown in the description of "ocnYvsYplot" below, all the arguments are "key" type, thus there is no way to put the first argument with "family waveforms"
    ocnYvsYplot(
    [ ?wavex o_wavex ?wavey o_wavey ]
    [ ?exprx o_exprx ?expry o_expry ]
    [ ?titleList l_titleList ]
    [ ?colorList l_colorList ]
    I have not try you method in a general condition, but I have the feeling that it will work, and also "unwrap" any of the remaining arguments, as mentioned by Andrew.
    Best Regards
    Yi
