  3. API for adding Calculator Function Categories
  • Subscribers 150
  • Views 13565
Curtisma
Curtisma over 8 years ago
Hello:
1. Is there a way to add a calculator function category using a SKILL function rather than by defining them in the "template catalog summary file"
2. Is there a way to define the category when using "calCreateSpecialFunction"?  I don't see a public argument for it.  Otherwise it just puts the category as "User Defined Skill Functions", not even "Special Functions" as you'd expect.
I already tried defining a new category by simply adding it to the "category" section of a function template but that didn't work.
-Curtis
    No - you can specify the category for template functions (via the fx button), but not with the old calCreateSpecialFunction mechanism - that only adds to the fixed "User Defined SKILL Functions" category. Not sure why you'd expect it to go to "Special Functions" - it's intended that these user defined SKILL functions go into the "User Defined SKILL Functions" category ;-)
