  3. Re-evaluate results with ADEXL
  • Views 17349
Driss
Driss over 8 years ago
I can re-run simulations from the terminal after they've bugged for some reason. The corresponding results are then accessible from the results browser, but unfortunatelly when I click on the "Re-evaluate results" button (in the ADEXL results panel), the expressions of the test are not updated... (espacially if I've previously cancelled the simulation before rerunning from the terminal)
I'm wondering if there is a simple way of forcing ADEXL to re-evaluate results from the data base in such a case.
Any idea?
Many Thanks
Cedric.
    Cedric,
    There's a drop-down menu next to the Evaluate icon which allows you to pick "incremental" (the default) or "full" evaluation. I think you'd need to ask it to do full evaluation here so that it forces to evaluate things it doesn't see as unchanged.
    Does that work?
  • Driss
    oops... I've missed this feature...yes, it works!
    Thanks for answering this.
    Kind Regards,
