  3. Draw random numbers from a normal distribution in an Ocean...
  • Subscribers 150
  • Views 16124
Draw random numbers from a normal distribution in an Ocean script
Alice92
Alice92 over 8 years ago
I want to study the effect of the parameter variabilty of a verilogA component. I would like to draw random numbers from a normal distribution when using desVar in my Ocean script.
How could I do this?
Thank you very much for your help
  • drdanmc
    drdanmc over 8 years ago
    I didn't see so much in the skill manual about generating random numbers from a normal distribution but you could use the Box-Mueller transform to get a sigma=1.0, mean=0.0 normally distributed random variable.  Then just scale by the sigma you want and offset by the mean you want.
    procedure( MYrandNorm()
    let((w, u1, u2, x1, x2)
    w = 2.0
    while( w >= 1.0
    ;; what we really want here is something uniformly distributed on [0,1]
    u1=1.0*random(m.MAX_INT) / m.MAX_INT
    u2=1.0*random(m.MAX_INT) / m.MAX_INT
    x1 = 2.0 * u1 - 1.0
    x2 = 2.0 * u2 - 1.0
    w = x1*x1 + x2*x2
    w = sqrt( (-2.0 * log(w) ) / w)
    y1 = x1*w
    y2 = x2*w
    ) ; ** let **
  • drdanmc
    minor correction, the u1,u2 generation should be
    u1 = 1.0*random(m.INT_MAX) / (m.INT_MAX - 1)
    u2 = 1.0*random(m.INT_MAX) / (m.INT_MAX - 1)
    note "INT_MAX", not "MAX_INT"
    Dan, Alice92,
    Meant to post this link to an earlier post - I wrote some code earlier which does this too (using the same method).
    Of course, I would ask why you're not just using a monte carlo simulation to do this  - set up a statistics block with the distribution of the random variable - that means you can do it natively in the simulator?
  • Alice92
    Thank you all for you replies.
    I think the monte carlo method might be better indeed.
