  3. removing quotes in skill
  • Views 17723
PK2017
PK2017 over 8 years ago
Is there an function available in cadence skill to remove double quotes?
I need to provide a = "0:0"  as input to a function, which wont take double quotes.
Please help.
PK
  • skillUser
    skillUser over 8 years ago
    Hi PK,
    You can use "evalstring" or "errsetstring" to evaluate the value/expression in the string and then supply it to another function.  The latter is safer and allows you to programmatically catch any errors.  Hopefully this is what you were looking for?
    Best regards,
    Lawrence.
  • PK2017
    Thank you Lawrence for the quick reply.
    One more question.
    I am trying to add a label to my layout using dbCreatelabel function.
    I was not able to specify the layer purpose using this.
    I have tried the following, its not working
    dbCreateLabel(cv "M10.pin" 0:0 "test" "centerCenter" "R0" "stick" 0.5)
    dbCreateLabel(cv "M10 pin" 0:0 "test" "centerCenter" "R0" "stick" 0.5)
    dbCreateLabel(cv 202.74 0:0 "test" "centerCenter" "R0" "stick" 0.5)
    Please help.
    PK
    dbCreateLabel(cv list("M10" "pin") 0:0 "test" "centerCenter" "R0" "stick" 0.5)
    is what you want. You can specify the layer number and purpose number too (so if that's 202 and 74, it would be list(202 74) ). However, specifying by name is almost certainly a better solution as it isolates you from the details of how the layer numbers and purpose numbers have been assigned for that technology.
