  3. detect and optional remove dangling/floating schematic lines...
  • Replies 7
  • Views 9614
detect and optional remove dangling/floating schematic lines?
drdanmc
drdanmc over 8 years ago
Anyone have a good skill approach to detecting and removing floating or dangling schematic lines?  For example, consider a schematic which had a bunch of 3 terminal resistors which were replaced with 2 terminal resistors.  Now there are little stubs that used to connect to the 3rd terminal.  These may be lines which are a single segment with a label on it or they may be wires that route some distance and connect to a net.
I can think of some hacks involving a while loop that calls mks = setof(X cv~>markers X~>parent~>objType =="line") and then deletes lines and then schCheck(cv) to update the markers but that seems a bit ugly.
-Dan
  • skillUser
    skillUser over 8 years ago
    Hi Dan,
    Maybe iterate over wire segments to identify those that are over a symbol but not over a pin?  Use dbGetOverlaps() or similar to look under both ends of the wire segment, if neither is over a pin shape (and perhaps checking that at least one point is inside an instance selection box, maybe even specifically resistors) then this could be a wire segment that you are looking for [I can imagine some cases where a wire performs a bend right next to the resistor before connecting to the pin and thus being flagged, but better to find false positives than miss some wires].
    Hope this helps,
    Lawrence.
  • drdanmc
    drdanmc over 8 years ago in reply to skillUser
    Thanks for the suggestion.  I was able to get something more or less working.  The couple of tricks were:
    keep_wire = nil
    foreach(pt fig->points
      ;;you can use a single point "bounding box"
      ;;restrict to wire/drawing lpp and top cv to get wires:
      r = dbGetOverlaps(cv list(pt pt) list("wire" "drawing") 0)
      ;; restrict to lines and paths
      r =  setof(X r member(X~>objType list("line" "path")))
      when(length(r) > 1 keep_wire = t) ;; we have a wire or path on this end
      ;; now look for connections to a symbol pin (1 == look this level and 1 down)
      r = dbGetOverlaps(cv list(pt pt) list("pin" "drawing") 1 )
      when(length(r) > 0 keep_wire = t) ;; we have a pin connection
    unless(keep_wire dbDeleteObject(fig))
    feels like a real hack and it will miss things like a wire that has a jog in it but is otherwise not connected.  But still, better than nothing.
    On a different note, what is the magic in this forum to paste code in a more code-like format?
  • skillUser
    skillUser over 8 years ago in reply to drdanmc
    Hi Dan,
    I use the full editor (which, of course, has just changed) and edit the HTML/source to change the 'p' tags to 'pre' tags and then further surround the SKILL with 'code' tags - each of 'pre' and 'code' need a start and end tag, but this seems to allow the code to stand out and read a little better.  I think Andrew uses a filter to add coloring to his code (I sometimes add bits by hand to color comments and so on).
    Best regards,
    Lawrence.
  • RK56
    RK56 over 8 years ago in reply to drdanmc
    Why not look for net names which do not connect to any instance?
    -Ramakrishnan
    Andrew Beckett over 8 years ago in reply to skillUser
    I have a CGI script to format my code library - it uses this under the hood (in essence):
    enscript --color --language=html -Eskill --output=- code.il > code.html
    If you then display code.html in a web browser, you can copy and paste the formatted code into the forum.
    That said, I do remember having to ensure I use an older version of enscript (1.6.1) because some of the italics were a bit odd in 1.6.4 (I can't quite remember though - this was going back a few years).
    Andrew Beckett over 8 years ago in reply to Andrew Beckett
    Sorry - I was wrong. I use enscript v1.6.5.1 because it fixed the earlier bugs in v1.6.4. I was looking at an old internal email when I was trying to use an older version with the scheme language mode; I later switched to the skill highlight mode.
  • drdanmc
    drdanmc over 8 years ago in reply to RK56
    The basic situation that started this was changing from some 3-terminal resistor symbols where the 3rd terminal typically had a little stub of  wire labeled as VDD or VSS.  After switching to a 2-terminal symbol, that stub was not needed but of course VDD and VSS still went to instances in other parts of the schematic so deleting by net name wasn't effective.
    -Dan
