  3. Plot expression after ADE-XL run
  • Replies 8
  • Views 22719
KGh94
KGh94 over 9 years ago
I have adopted this piece of art from Andrew's post in this thread:
historyName=axlGetHistoryName(abXLRunAfterSimGetHistory())
    ; example of getting the resDB in this script
    resDB=axlReadHistoryResDB(historyName)
    foreach(point resDB->points()
        foreach(corner point->corners()
            printf("CORNER: %L\n" corner->name)
            foreach(test corner->tests()
                printf("TEST: %L\n" test->name)
                foreach(output test->outputs()
                    printf("  %s: %L\n" output->name||"" output->value)
This code works fine, except for the expressions values which are considered to be "wave". I would like to plot these waves using ViVa, so I edited the code:
when(output->value == "wave"
awvPlotWaveform(newWindow() list(output->valueAsString))
) printf(" %s: %L\n" output->name||"" output->value) ) ) ) )
The problem is with expressions in particular, which seem to be not view-able outside ADE-XL. So I get the warning:
*Warning* Wavenil is not a waveform object that can be displayed and will be DELETED automatically.
Is there a work-around for this? Any insight would be highly appreciated.
Best regards,
Karam
    Hi Karam,
    You need to re-evaluate the expressions. Something like this magic should do the job:
    procedure(abReadStuff(historyName @optional (session axlGetWindowSession()))
        let((resDB testTable testExprTable hist sdb sevSess asiSess expr name)
            sdb=axlGetMainSetupDB(session)
            hist=axlGetHistoryEntry(sdb historyName)
            testTable=makeTable("test" nil)
                        ; first time we come across the test, record all the
                        ; expressions from the info recorded in that history
                        ; in a table to make them easier to find
                        unless(testTable[test->name]
                            testExprTable=makeTable("testExpr" nil)
                            testTable[test->name]=testExprTable
                            sevSess=axlGetToolSession(session test->name ?history hist)
                            asiSess=sevEnvironment(sevSess)
                            foreach(out asiGetOutputList(asiSess)
                                when(out->expression
                                    name=out->name || sprintf(nil "%L" out->expression)
                                    testExprTable[name]=out->expression
                        ; Now iterate over the outputs and for "wave" expressions
                        ; open the results for that specific point, pull out the
                        ; expression, and evaluate it
                            if(output->value == "wave" then
                                expr=testTable[test->name][output->name]
                                if(expr then
                                    openResults(test->resultsDir)
                                    errset(
                                        plot(eval(expr))
                                else
                                    printf("Cannot find expression for output %L\n"
                                        output->name
                            else
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your continued wizardry. It looks like you are saving the expressions along with their names in a table and then retrieving the expression if it shows up in the test. Doesn't that scale expensively with an increased number of plots? I have implemented the following:
    when( output-> value == "wave"
        out=calcVal(output->name test->name ?cornerName corner->name)
        windowID=newWindow()
        awvPlotWaveform(windowID list(out))
    I have also set an exception for nominal corner since it is apparently stored in corner->name as "nominal" but when using calcVal it has to be written as "Nominal", with a capital N, to avoid an error.
    Is there a problem with my version of plotting the waveform?
    Additionally, my legend position is set to "inside" by default. When attempting to save the plot using:
    saveGraphImage(?window windowID ?fileName fileName ?quality 100 ?backgroundColor "white")
    The legend does not appear in the image. It seems that the legend takes some time to appear. so I used hiRegTimer("savePlot(windowID fileName)" 50) to save the plot after the simulation ends. Is there a better way to do this?
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Karam,
    That's a good point - calcVal is a pretty reasonable way of doing this which is rather simpler than mine! I'd forgotten that it can be used for this (I've done it that way too).
    The graph image problem you're describing was a timing issuing in the code that I thought had been fixed a while back; which IC subversion are you using?
  • KGh94
    Hello Andrew,
    Glad to know I'm in the right track. I am using 6.1.7-64b.500.9. So until an update rolls out, I have to stick to hiRegTimer()?
    Best regards,
    Karam
    Karam,
    The issues I'm thinking of should have been resolved by the version you're using, so please report this to customer support. Probably using the timer is the only workaround in the meantime (I'm assuming adding ?enableLegend t doesn't make a difference - I wouldn't expect it to).
    Of course it would be worth checking with a later hotfix first in case it got fixed and I just didn't find a report of the issue (the latest is IC617 ISR16).
  • KGh94
    I tried adding ?enableLegend t but it didn't help. To be fair, the legend box is captured in the image, only the text (and line color indicator) is missing. I would have been satisfied if it was the other way around, though.
    Best regards,
    Karam
  • KGh94
    Hello Andrew,
    Merry Christmas! I hope you're enjoying the holiday season. I have a question regarding calcVal:
    I am using out=calcVal(output->name test->name ?cornerName "Nominal") to get the plot for nominal corner only. However, when plotting out with awvPlotWaveform(newWindow() list(out)) it plots the result across all corners. What is confusing is that this happens for certain outputs only. Have you come across such an issue before?
    Edit: This happens when two outputs (in two different tests) have the same name and expression. The result shows "sim err" for one of the outputs and it seems like this has an effect on calcVal.
    Best regards,
    Karam
    Karam,
    No, I've not seen this. Sounds like a bug. Please contact customer support...
