  3. Change default VIA definition
  • Views 16021
DavidQ90
DavidQ90 over 8 years ago
I change the default via for AP to M9 with:
viaSetDefaultValidViaDefs("tsmcN40" "virtuosoDefaultSetup" list("AP_M9_3x3") nil)
However when I try to draw a via using:
viaGenerateViasInArea(cvId points myViaOptions)
no vias are drawn. Without changing the default value vias are drawn as expected.
When I open the Create Via form in Layout I can see the default changed to the correct value. Any help on why no vias are being drawn?
    Probably would need to see complete setup and code. Suggest you contact customer support.
