  3. dbGetNeighbor question
  • Views 14838
psill000
psill000 over 8 years ago
I am using the dbGetNeighbor function it returns the correct shape and distance for rectangles, but if the object is a polygon it returns the upper edge rather than the closest edge. Example a L shaped polygon turned counter clockwise.
Is there a way to get the lower edge distance without shape manipulation or stepping points to see in point is in fig, leIsPointInsideFig.
Paul
  • psill000
    I implemented a stepping by grid scripting to find the edge. It seemed the simplest way  to find the closet edge from the point.
    Paul
