  3. How to dynamic change the number to format ( Writes formatted...
  • Views 16891
How to dynamic change the number to format ( Writes formatted output to a port.) ?
Charley Chen
Charley Chen over 8 years ago
Hi All,
How to dynamic change the number  10 ==> 15 ?  ( Writes formatted output to a port.)
I want 10s is not fixed , it dependents on a interger variable (e.g. a = 10 , a= 15)
fprintf( op "%10s\n" line)  => fprintf( op "%15s\n" line)
Thank you,
Charley
    Andrew Beckett over 8 years ago in reply to Charley Chen +1
    Using evalstring (and hence run-time evaluation) is a really bad way of doing this - it's unnecessary. You can take the same idea but do it much more cleanly and without needing to revert to run-time evaluation…
  • RK56
    RK56 over 8 years ago
    How about this way? Create a string with the required format and then evaluate the string. I remember Perl having a way of doing this directly but not in skill. Others please correct me.
    fmtCmd = sprintf(nil, "printf(\"%%%ds\n\" \"line\")" formatInt)
    evalstring(fmtCmd)
    -Ramakrishnan
  • Charley Chen
    Charley Chen over 8 years ago in reply to RK56
    Hi Ramakrishnan ,
    Yes, It works. Thank you.
    Charley
    Using evalstring (and hence run-time evaluation) is a really bad way of doing this - it's unnecessary. You can take the same idea but do it much more cleanly and without needing to revert to run-time evaluation:
    sprintf(formatStr "%%%ds\n" fieldWidth)
    fprintf(op formatStr line)
    Unfortunately SKILL doesn't support the "%*s" construct that the C printf does, which would have made this even easier.
  • Charley Chen
    Charley Chen over 8 years ago in reply to Andrew Beckett
    Hi Andrew ,
    It's OK for one field.
    If i have 4 field needs to op , How to write ?
    Thank you,
    Charley
  • RK56
    RK56 over 8 years ago in reply to Andrew Beckett
    Agreed. This is much netter
  • Charley Chen
    I got it. It works. Thank you very much
    sprintf(formatStr "%%%ds  %%%ds  %%%ds  %%%ds\n" fieldWidth  fieldWidth  fieldWidth  fieldWidth)
    fprintf(op formatStr line1 line2 line3 line4)
    Charley
