  3. Determine Cellview used in Test using SKILL in ADE-XL
  • Views 16247
KGh94
KGh94 over 8 years ago
I am running multiple tests on ADE-XL. Each test runs a different cellview (schematic, config, etc.). Is it possible to determine which cellview is my test running (using SKILL in CIW)?
Example:
car(car(resDB->points())->tests())->cellview
Also is saving a config cellview as a table possible from CIW?
Any hints would be highly appreciated.
Best regards,
Karam
    Karam,
    sess=axlGetWindowSession()
    sdb=axlGetMainSetupDB(sess)
    foreach(testName cadr(axlGetTests(sdb))
      test=axlGetTest(sdb testName)
      toolArgs=axlGetTestToolArgs(test)
      printf("Test %s %s/%s/%s\n" testName
        cadr(assoc("lib" toolArgs))
        cadr(assoc("cell" toolArgs))
        cadr(assoc("view" toolArgs))
    You can't do it from the test object in the RDB - that tells  you the test name, but not the lib/cell/view of the test bench.
  • KGh94
    KGh94 over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your response. This works like a charm!
    Is there a function to save the config cell-view as a table?
    Example:
    libName=cadr(assoc("lib" toolArgs))
    cellName=cadr(assoc("cell" toolArgs))
    viewName=cadr(assoc("view" toolArgs))
    when(hdbIsConfig(libName cellName viewName)
        saveAsTable(libName cellName viewName mySaveDirectory)
    Your kind assistance would be highly appreciated.
    Best regards,
    Karam
    Andrew Beckett over 8 years ago in reply to KGh94
    Karam,
    What do you mean by saving a config view as a table? Do you mean the equivalent of File->Save Cell Table Data in the hierarchy editor?
    If so, the answer is no. You'd have to write something yourself using the "hdb" APIs to collect the information. You could look at <ICinstDir>/tools/hdb/examples/hdbTraverse.il as a starting point.
  • KGh94
    Hello Andrew,
    Your assumption is correct, I was referring to the equivalent of File->Save Cell Table Data in the GUI.
    I will check out the file, thank you for your tremendous help. I highly appreciate it.
    Best regards,
    Karam
