  3. How can I get the RGB values from a color name?
  • Views 15204
KevinWH
KevinWH over 8 years ago
I'm using drGetPacket to get the fill color name.
I would like to convert this name to the appropriate RGB values.
How could I do this?
If this is not possible, how could I get a list of all possible fill color names?
With that, I could write my own function.
    If you looked in the documentation for drGetPacket, you should find the function drGetColor nearby which would tell you the RGB definition of the color. For example:
    drGetColor("display" "pink")
    ("display" "pink" 255 191 242
    nil
    There is no public SKILL function to retrieve the color names (the color names are defined in the display.drf file - potentially that could be parsed should you really want to find out all the current color names).
  • KevinWH
    KevinWH over 8 years ago in reply to Andrew Beckett
    Thanks! That worked.  I should've seen that in the docs.
