  3. Change the FetType using skill
  • Subscribers 148
  • Views 1667
FormerMember
FormerMember over 8 years ago
I wanted to change the Fet type of a mos instance from egnfet to lvtnfet (or any other type).
Currently I am using this snippet for a cell view with only one instance.
cv=gegetWindowCellView()
x=cv~>instances
schReplaceProperty(list(x)  "fetType"  "lvtnfet")
after executing this snippet
when I type
x~>fetType
it displays "lvtnfet".
But when I generate the CDL, the fetType is still displayed as "egnfet".
I am able to change every other cdf parameter using the above snippet and it is also displayed in CDL correctly except fetType.
Please tell a solution for the problem.
Regards
Utkarsh
    Andrew Beckett over 8 years ago +1
    Without knowing the details of your PDK, it's hard to know whether what you are doing makes sense (well, I'm sure it doesn't make sense because it didn't work!). For a start, I have no idea whether "fetType…
    Without knowing the details of your PDK, it's hard to know whether what you are doing makes sense (well, I'm sure it doesn't make sense because it didn't work!). For a start, I have no idea whether "fetType" is actually a CDF parameter for the devices in your library, and even if it is, whether it affects simulation or CDL netlists.
    Sometimes you would need to change a parameter and then call the CDF callbacks; other times you would need to change the master (i.e. change the instance to be another device) and then call the callbacks. Sometimes that won't work either because some of the CDF parameters may have storeDefault=yes in the CDF and consequently keep an old model name or old property value from the previous instance.
    My suggestion would be to contact customer support so that an application engineer can look at this with you.
  • FormerMember
    FormerMember over 8 years ago in reply to Andrew Beckett
    Hi Andrew
    Yes its a cdf parameter.
    I would look forward to contact an Application Engineer. Thanks.
    Regards
    Utkarsh
