  3. Toolbar info and syntax
  • Views 14848
psill000
psill000 over 8 years ago
Is it possible to define the comboBox size?
What is the syntax to have a toolbar item grayed out when in read mode?
Paul
    If you use Options->Toolbars and add a new toolbar item, you'll see that you can specify the width of a comboBox - in an "overlays" file (which is the same syntax as the toolbars file - but preferred because it means you don't have to maintain a copy of the standard toolbars or include the standard toolbars) you can specify this with the width attribute.
    To have an item grayed out, you'd use enableCondition editable . Note however that comboBox items don't seem to support this though (it's not on the toolbar editor either for comboBox items).
