  3. Skill debugger issue
  • Views 14913
Julien Terrier
Julien Terrier over 8 years ago
I use Virtuoso  Layout Suite L to layout different kind of component, currently I'm working on new technology and since I start with that techno I met a problem when I use the skill debugger ( ic 06.17.714 ).
Before I could go step by step with skill debugger ( ic  06.17.709 ) but now I can only add some breakpoint, and when I load the skill with some breakpoint,  The breakpoint don't work anywhere only in front of procedure then I would like go step by step Inside my procedure but it doesn't work.
I know it's not due to ic version as I tried with ic 06.17.714 in old technologie/configuration and the skill debugger works.
I'm almost sure it's due my  new configuration set from design kit but I don't know where I must look to check skill debugger parameter ?
and regarding this path what does it mean ==> ~/.cadecnce/skill_dev.il
Tell me if you need more information about my issue.
    I have no idea what your actual problem is from the description above - it's really not clear.
    I'm not aware of any file ~/.cadence/skill_dev.il (there are files there called skill_ide or skill_ide_hi which contain preferences saved from the last session, but not a skill_dev.il file).
