  3. Term net name changing for the pins automation using SKILL...
  • Views 16891
Term net name changing for the pins automation using SKILL code
Odin Ciociea
Odin Ciociea over 8 years ago
I am on Virtuoso IC6.1.7
I want to change by SKILL code the pins net names for a certain block.
I use in my code something like :
[..]  term->net->name = "new_value"
and I get an dbSetq error (DB-370034)
N.B. term~>name I can change with no problem, but it does not help me.
Somehow this property value cannot is read-only. How can it be changed automatically?
Can anyone tell help me on this one?
Thank you,
BR,
Odin
    Andrew Beckett over 8 years ago +1
    Odin, You would need to use dbMakeNet() to create a net with the new name, and then use dbMergeNet to merge the existing net onto that new net (only the new net then survives). Regards, Andrew
    Odin,
  • Odin Ciociea
    Odin Ciociea over 8 years ago in reply to Andrew Beckett
    Hello Andrew,
    Many thanks for your advice, I did it so and it works fine.
    Kind Regards,
    Odin
