  3. Updating a form in Skill
  • Views 17972
mschw
mschw over 8 years ago
i have a question on how forms are updated in Skill when properties of elements in the form are changed in the background.
Within the following small example a form with a button gets insatiated.
button=
hiCreateButton(
                              ?name 'button
                              ?callback "printf(\"Button pushed\")"
                              ?buttonText "Push"
);hiCreateButton
form=
hiCreateAppForm(
                                ?name 'myform
                                ?fields list(button)
                                 ?formTitle "Simple Form"
);hiCreateAppForm
hiDisplayForm(form)
If i enter the code line form->button->enabled=!form->button->enabled several times in the CIW, the button gets enabled/disabled. If I enter the code line button->enabled=!button->enabled nothing happens at all, although the property changes. Is there a way to update the form, if the enable property will be changed using the second way?
Many thanks.
Best regards,
Matthias
  • mschw
    OK, i figured this out myself: the Button can be enabled using hiSetFieldEnabled(button t).
    However, it would be interesting to know what the difference between hiSetFieldEnabled(button t) and button->enabled=t  is.
  • skillUser
    skillUser over 8 years ago in reply to mschw
    Hi Matthias,
    Essentially the API access hiSetFieldEnabled(button t) is about the same as accessing the button structure and changing the enabled attribute, but I think that your question is more about the name scoping and access.  For example the button variable can (and should be) local to your procedure that builds the form fields and the form, but the form variable itself has to be global - you can refer to it locally as form and this is fine but outside of the scope (let or prog for example) you can refer to it as myform.  So at a global scope you can do myform->button->enabled = !myform->button->enabled to toggle the enabled state, or you could use hiSetFieldEnabled(myform->button t) to set it to be enabled.  If you didn't even use a let() or prog() statement I still would not try to refer to the 'button' variable directly, only through the 'hierarchy' of the form structure; then we are referring to the button that is placed/instantiated on the form.
    Hopefully this helps explain things a little?
    Best regards,
    Lawrence.
  • mschw
    mschw over 8 years ago in reply to skillUser
    Hi Lawrence,
    thanks for your detailed explanation, it is very useful for me.
    Best regards,
    Matthias
