  3. Programmable version of leHiCreateBus
  • Subscribers 150
  • Views 15569
MatthewLove
MatthewLove over 8 years ago
I'm looking to create a bus of wires using skill but the only function that I can see, leHiCreateBus, expects human input.
Is there a more programmable version somewhere that I'm not seeing?
If there isn't, do you know what functions I can use to emulate human input through skill?
Matthew
  • mschw
    mschw over 8 years ago +1
    Hi Matthew, you can take a look at the Virtuoso Relative Object Design (ROD) User Guide. There are several code examples, including one on how to create a Bus. Best regards, Matthias
  • mschw
    Hi Matthew,
    Best regards,
    Matthias
  • MatthewLove
    MatthewLove over 8 years ago in reply to mschw
    Hi Matthias,
    Thanks for the suggestion. The section on multi-part paths looks to be what I need.
    Matthew
    Andrew Beckett over 8 years ago in reply to MatthewLove
    I should point out that leHiCreateBus does a whole lot more than just creating a multi-part path does - but if you just want a subset of its features, maybe that's sufficient...
    It's really intended to be an interactive tool - not something scriptable (that would be more of a case of using the auto-routing capabilities).
  • MatthewLove
    MatthewLove over 8 years ago in reply to Andrew Beckett
    I'm mainly just looking to create parallel conductors so I can make a pcell for a spiral transformer.
    The bus option means I only have to generate a single set of coordinates which saves me time.
    leHiCreateBus was just the first option that I found.
