  3. Run Assura SVS from command line
  • Views 16352
Amar Kumar
Amar Kumar over 8 years ago
I am trying to run the assura SVS(Schematic Vs Schematic) from the command line using the below command.
"assura <svs rsf file>"
However I am not sure about the RSF file format. I did the same for assura LVS and DRC earlier. As am new to the SVS, please help me to do this.
Tool : Cadence 6.1.7
Thanks & Regards,
Amar
    Amar,
    This is covered in the Assura Physical Verification User Guide. If you invoke $ASSURAHOME/tools/bin/cdnshelp and then open this document. There's a chapter called Comparing Layout and Schematic Netlists and at the very end of that, there's a section Comparing Two Schematics which should tell you what to do.
