  3. How to corrupt a GDS with dbCreateParamInst
  • Views 15386
tweeksii
tweeksii over 8 years ago
Recently one of our new SKILL programmers (lets call him Obi Wan) discovered a way to update a pcell such that it streams out "successfully" (i.e. 0 errors), but the resulting GDS cannot be opened by Calibre DRC/DRV.  (I did not attempt to stream it back in to Virtuoso, but presumably that would have failed as well.)
After careful debugging, he narrowed the problem down to this line:
         dbCreateParamInst( pcCellView cvDbShapeStaggered nil origin "R0" 2 pcellParamList )
Obi Wan had copied this pcell code from another pcell so that he could make a small change.  In the original pcell (which streams out without issue), the corresponding line is the same, save for one tiny detail:
                    dbCreateParamInst( pcCellView cvDbShapeStaggered nil origin "R0" 1 pcellParamList )
I.e. the "numInst" parameter was 1 in the working pcell, and accidentally setting it to 2 broke streamout!
That mysterious "numInst" parameter to dbCreateInst, dbCreateParamInst, etc. has always bothered me.  What does it do, exactly?  Apparently, if you dare to set it to something other than 1, it silently corrupts your GDS!  :P  The documentation doesn't say what's supposed to happen when numInst > 1 (do I get two instances on top of each other?), but it does say it works with the instance name (e.g. "I3<1:0>"), so I'm guessing this parameter is meaningful for schematics, but not for layouts?
Anyway, it's troubling that XStreamOut generated a garbage GDS without throwing an error, or even a warning about it!  Can anyone from Cadence reproduce this on their end, or would you like a testcase?
    The numInst parameter creates the instance as a vector rather than a single instance. For layouts, that's a bit pointless, but for schematics you end up with a vectored name.
    I don't know what you mean about it "corrupting your GDS". I don't see any problem with the stream file generated - there's a single instance in the stream file which is what I'd expect. Nothing appears to be wrong with the stream file as far as I can tell.
  • tweeksii
    tweeksii over 8 years ago in reply to Andrew Beckett
    Even when you set numInst to 2?  Intereseting....
    Well thanks for trying to duplicate it.  Maybe it has something to do with the particular pcells that we were using (or the fact that it was a pcell that made the dbCreateParamInst call).  I should stop being lazy and file a proper testcase. Slight smile
    Andrew Beckett over 8 years ago in reply to tweeksii
    Tom,
    i’d tried both creating an instance in SKILL with numInst as 2 and doing so within a pcell. Both were ok for me. So there must be some subtlety to the issue. So if you could contact customer support, that would be great!
    BTW, I approved your other reply (to the stream out from VM question) because it got moderated by the automatic spam detection for some reason - sorry about that
