  3. Change color/width of selected net via SKILL code
  • Replies 9
  • Views 7644
LuisGutierrez
LuisGutierrez over 8 years ago
Hi all,
I'm working with multi voltage designs and I would like to use color/width coding in the wires of the schematic to illustrate low,medium and high voltage domains. The idea is to change the width and color of a selected net (not only the wire segment) with via a hotkey after having selected it with a mouse click. Essentially it would be something as highlighting a net but instead of temporarily changing its properties, do it permanently.
Has anybody done this successfully?
  • skillUser
    skillUser over 8 years ago in reply to LuisGutierrez +1
    Hi Luis, You can modify the code so that the first (arbitrarily) object in the selected set is used to find the net and then find the figures on that net, then for each figure that is a line ("wire segment…
  • skillUser
    Hi Luis,
    I just tried the following and it seemed to work:
    foreach(mapcar obj geGetSelectedSet() when(obj~>objType=="line" schSetWireColor(obj "green")))
    for setting the selected wire segment(s) to be 'green' in color.
    There is also a function schGetWireColor(). For the line thickness there is schSetWireLineStyle(), so combining this also:
    foreach(mapcar obj geGetSelectedSet() when(obj~>objType=="line" schSetWireColor(obj "green") schSetWireLineStyle(obj "thickLine")))
    Hopefully this is what you are looking for? You should be able to see the color names when manually setting the wire color. For thicknesses, the default is "solid", thicker is "thickLine2" and thickest is "thickLine" I think.
    Lawrence.
  • LuisGutierrez
    LuisGutierrez over 8 years ago in reply to skillUser
    Hi Lawrence,
    Thank you for your reply. This is certainly going in the right direction. However, this command would only change the color of the selected wire segment. My idea is to change the color of the entire net, -which is composed of several wire segments- when selecting only one of such wire segments.
    I wonder if there is an environment variable such as schSetNetColor (or something similar) that allows the intended behavior. Ultimately the idea is to bind this behavior and the thickness modification to a key.
  • skillUser
    Hi Luis,
    You can modify the code so that the first (arbitrarily) object in the selected set is used to find the net and then find the figures on that net, then for each figure that is a line ("wire segment") it has the properties changed for that segment:
    foreach(mapcar obj car(geGetSelectedSet())~>net~>figs
    ); when
    ); foreach
    Best regards,
    Lawrence.
    Andrew Beckett over 8 years ago in reply to skillUser
    I should also point out (me being Mr. Pedantic) that the mapcar keyword is unnecessary here because you're not using the return value of the foreach. It actually costs more (a little) to collect the list of return values when using foreach mapcar, so unless you need the return values, there's little point in doing this. An ordinary foreach would suffice here.
  • skillUser
    skillUser over 8 years ago in reply to Andrew Beckett
    Very true. I used the mapcar during development/testing to check the return values of the function inside the loop, but left it in. Sometimes I wrap the foreach(mapcar ... with a "forall" to gain the overall return value. Thank you for noticing that I'd left it in, it could cause confusion...
  • LuisGutierrez
    Thank you Lawrence!
    Works like a charm.
  • ssram
    ssram over 8 years ago in reply to skillUser
    But, how do i remove these coloring to get the default?
  • skillUser
    skillUser over 8 years ago in reply to ssram
    Choose "cadetBlue" for the color and "solid" for the lineStyle.
    foreach(obj car(geGetSelectedSet())~>net~>figs
        schSetWireColor(obj "cadetBlue")
        schSetWireLineStyle(obj "solid")
      ); when
    ); foreach
    Lawrence.
    Lawrence's suggestion does reset the color and line style overrides on the wire (i.e. it removes the info in the database with the override) provided that the color and line style match the info for the packet used for the wire. So strictly speaking you should do:
    packetName=techGetLPPacketName(techGetLP(tf list("wire" "drawing")))
    defaultLineStyle=nth(3 drGetPacket("display" packetName))
    defaultColor=nth(5 drGetPacket("display" packetName))
    Then in Lawrence's code you could do:
    schSetWireColor(obj defaultColor)
    schSetWireLineStyle(obj defaultLineStyle)
