  3. How to know the cut class of via which is already creat...
  • Subscribers 152
  • Views 18249
How to know the cut class of via which is already created
raosathish
raosathish over 8 years ago
HI , i am trying to access various parameters of via like via definition , rows, columns, cut class etc. through SKILL.
I found other parameters but din''t get how to get the cut class of via. can anyone help me on this.
Sathish N
    Hi Sathish,
    The cut class is not recorded in the viaHeader - the edit properties form tries to infer the cut class from whatever the cutWidth/cutHeight are (at least I think that's what it's doing from a few experiments; I even changed one of the cutWidth/cutHeight and it still matched it against the "best fit" for cut class it could find).
  • psill000
    psill000 over 8 years ago
    I was kinda working on something similar to you.
    Its kinda a work in progress of how to get a via cutClass
    You can read more about cutClass from the cdshelp search "accessing cutClass"
    If you need all the via names
    allViaNames = techGetTechFile(geGetEditCellView())~>viaDefs~>name
    viaDb = car(geGetSelSet())
    procedure(stdLib_getViaCutClass(viaDb)
    let( (lib techId foundaryCg cutLay cutClassCg name sz cutSzList)
    lib = viaDb~>viaHeader~>master~>libName
    techId = techGetTechFile(ddGetObj(lib))
    foundryCg = cstFindConstraintGroupIn(techId "foundry")
    cutLay = stdLib_getViaCutLpByViaDb(viaDb)
    cutClassCg = car(setof(cg foundryCg~>objects equal(cg~>defName "cutClass")))
    foreach(cut cutClassCg~>objects
          if(equal(car(cut~>layers) cutLay) then
                name = cadar(cut~>params)
                sz = cut~>value
                cutSzList = cons(list(name sz) cutSzList))
    cutSzList
    ); end of let
    ); end of stdLib_getViaCutClass
    procedure(stdLib_getViaCutLpByViaDb(viaDb)
    let( (lib techId lp1 lp2 viaCut
    case(viaDb~>objType
                 ("stdVia" lp1 = viaDb~>viaHeader~>viaDef~>layer1~>name
                      lp2 = viaDb~>viaHeader~>viaDef~>layer2~>name)
                ("stdViaDef" lp1 = viaDb~>layer1~>name
                      lp2 = viaDb~>layer2~>name)
    foreach(vLp techGetViaLayers(techId)
          if(member(lp1 vLp) && member(lp2 vLp) viaCut = cadr(vLp))
    viaCut
    ); end of let
    ); end of stdLib_getViaCutLp
    Paul
  • raosathish
    raosathish over 8 years ago in reply to Andrew Beckett
    Thanks Andrew
  • raosathish
    raosathish over 8 years ago in reply to psill000
    thanks paul will check it once
