  3. Search and replace in a sub list
  • Views 19595
WTony
WTony over 8 years ago
Hi
I would like to do a search and replace in a sub list.
suppose I have : myList = list(list("a" "b") list("c" "d"))
the list can also be myList = list(list("c" "d" "e") list("a" "b" "f"))
the sublist length is not constant
I don't know in advance where the character is in the list. the only Information I have is the variable "myList", the character I need to search "b" and the string I need to replace "newB"
how can I replace "b" by "newB"
result:
 myList =(("a" "newB") ("c" "d")) or myList = (("c" "d" "e") ("a" "newB" "f"))
thanks for help
  • WTony
    I found a solution buy I'm not sure it's optimal.
    foreach(subList myList
       if( member("b" subList) then
        rplaca(member("b" subList) "newB")
    Andrew Beckett over 8 years ago in reply to WTony
    Two more general solutions. These work with any depth of lists, with any length of the sublists, and change all occurrences of the original value with the new value. The first is non-destructive - i.e. it constructs a new list with the same structure and doesn't disturb the original list:
    ; Non-destructive version - constructs a new list
    procedure(CCFreplaceDeep(theList orig new "lgg")
        foreach(mapcar elem theList
            cond(
                (listp(elem) CCFreplaceDeep(elem orig new))
                (elem==orig new)
                (t elem)
    The second is a destructive version - it changes the original list in-place. So it's more memory efficient (creates less garbage) but it has the side-effect of modifying the original list:
    ; Destructive version - replaces list elements in place
    procedure(CCFreplaceDeepInPlace(theList orig new "lgg")
        foreach(map remainder theList
            cond(
                (listp(car(remainder))
                    CCFreplaceDeepInPlace(car(remainder) orig new))
                (car(remainder)==orig rplaca(remainder new))
        theList
  • WTony
    WTony over 8 years ago in reply to Andrew Beckett
    thanks Andrew, I'll try it
