  3. get via coloring
  • Subscribers 150
  • Views 17263
get via coloring
psill000
psill000 over 8 years ago
Is there another method of getting and setting the via coloring?
I had a used a script to get and set via coloring but it doesnt seem to work now.
The via is a stdVia with mask2Color locked on layer2 as indicated from the property gui
I have tried
dbGetViaLayerControl
dbGetViaCutLayerControl
dbGetViaLayer1Control
dbGetViaLayer2Control
dbIsViaColorStateLayerLocked
dbGetViaLayerNumColorMasks
All return noColor, noShift or nil
Paul
  • TaherEssam
    TaherEssam over 8 years ago
    Paul,
    Should be sth similar to this code:
    layer1Num = via_Id->viaHeader->viaDef->layer1Num
    layer2Num = via_Id->viaHeader->viaDef->layer2Num
    cv_id = dbOpenCellViewByType( "wo_kourany" "test" "layout" "maskLayout" "r" )
    drGetPacket("display" techGetLPPacketName(car(nth(layerNum1 techGetTechFile(cv_id)->layers)->lps)))
    Output should like this:
    ("display" "Metal4Bnd" "blank" "solid" "yellow"
        "yellow" "outline"
    Taher.
    Andrew Beckett over 8 years ago in reply to TaherEssam
    Taher - wrong kind of color. You're talking about the display color, whereas this is about Advanced node coloring (which is related to multiple patterning of the masks - each metal1 mask is assigned a color name to distinguish it).
    Paul - to get whether the via mask is locked, you'd use dbIsViaColorStateLayerLocked(viaId "cutLayer") ; or "layer1" or "layer2". There is also the function dbSetViaColorStateLayerLocked to set the lock status of each layer. There's also dbSetViaColorInfo which allows you to set the color and the lock status of each layer (and in fact do all of them in one shot) - this function was added in ICADV122 ISR6 (so also in ICADV123 ISR7 which was the subsequent ISR). The dbGetViaLayerControl/dbSetViaLayerControl and the individual db{Get,Set}Via{Layer1,Layer2,CutLayer}Control functions also work too (although you need to make sure they are unlocked before changing them). The control is described as a shift (so noColor==grey, noShift==mask1Color, shift1=mask2Color).
    Unfortunately there's no nice dbGetViaColorInfo which I think would make life a bit simpler...
    I would say that the documentation for dbSetViaColorInfo shows setting them together, and then retrieving them with the individual APIs.
  • TaherEssam
    TaherEssam over 8 years ago in reply to Andrew Beckett
    Andrew,
    Thanks for clarification, wasn't very clear from the description.
    Taher.
