  3. how to make 2 lists independent to each other
  • Views 15329
WTony
WTony over 8 years ago
I have a weird problem in my skill code that I can't explain. I need help for the explanation.
aList = list(list("a" "1") list("b" "2") list("c" "3") list("d" "4") list("e" "5") list("f" "6") list("g" "7") list("h" "8"))
bList = list("a" "b" "d" "g" "i" "j")
newList = nil
foreach(subList bList
findList = assoc(subList aList)
if(findList then
newList = cons(findList newList)
foreach(subList newList
if(member("b" subList) then
rplaca( member("b" subList) "bb")
the result is :
newList = (("g" "7") ("d" "4") ("bb" "2") ("a" "1"))
aList = (("a" "1") ("bb" "2") ("c" "3") ("d" "4") ("e" "5") ("f" "6") ("g" "7") ("h" "8"))
why aList also changed?
Does those 2 lists a linked somewhere?
How can I make them independent? So when I change the newList, it doesn't change in aList.
Yu Hao
    Hi Yu,
    It's not surprising in the least. SKILL attempts to keep most list operations as efficient as possible, and shares lists where it can. Your original aList is a set of list cells, each with a pointer to a sub-list. When you construct newList, you are just referencing those sub-lists again rather than making a copy of them. This is the kind of thing I always explain on the whiteboard when teaching SKILL - understanding how lists are stored helps to understand both efficiency and also the impact of destructive operators.
    This is generally a safe thing to do, because most list operations in SKILL are what are called non-destructive. However, in your second block of code, you are using rplaca, which is a destructive operator (there are very few destructive operators in SKILL). There's several ways around it (particularly if you know the structure of the list - you potentially could just avoid using rplaca), but one simple way is to use copy() to copy the sublist when creating the newList if you know you're going to use rplaca.
    newList=nil
      if(findList then
        newList = cons(copy(findList) newList)
    Now if you do the block of code with rplaca, aList will be unaffected, because the newList will be independent of the contents of aList.
  • WTony
    WTony over 8 years ago in reply to Andrew Beckett
    Thanks Andrew for the explanation
