  3. skill command for layout execution
  • Replies 26
  • Subscribers 152
  • Views 39850
Supriyo
Supriyo over 8 years ago
I am trying to get familiar with skill by following commands printed on CIW. There are few layout related questions on that.
1)  These are the set of commands that get printed when I execute “generate all from source” from virtuoso layout editor.
        lxHiReInitDesign()
        hiiSetCurrentForm('lxTemplateForm)
        lxTemplateForm->templateTab->page1->pMinSep->value=1.0
        hiFormDone(lxTemplateForm)
When I execute them in skill file, the interactive window appears and asks for user input. How do I pass the user input in the skill file itself as function argument.
2) For the interdigitization, I see set of commands get executed when modGen is called, some of them are shown below. But the same commands fail to work from skill. What function call with arguments should I use to interdigitate for example two transistors with 2 fingers each with a pattern ABBA.
mgCreateOrEdit(geGetEditCellView() “nil” “nil")
mgPatternCB()
hiiSetCurrentForm('patternForm)
patternForm->g_patternRadio->value= "Customize"
hiFormDone(patternForm)
mgAbutAllCB()
3) I am calling chip level routing assembly from skill the following way.
        ipcBeginProcess("/package/eda/cadence/IC616/tools/iccraft/bin/vcar -lib tutorial -cell amplifierDemo -view layout.routed.routed  -constraintGroup virtuosoDefaultSetup  -protectPreRoutes  -o router_01-31-2018_17:13:26.log”)
When I execute detailed routing on the new window, I do not see any command appearing on CIW, may be because the routing tool runs independent from virtuoso. What function call would be involved after the command above to run detailed routing with say 25 passes. I am guessing same problem would occur while invoking calibre drc, lvs and then passing arguments on them.
Regards
Supriyo
    Andrew Beckett over 8 years ago in reply to Quek
    Supriyo,
    I should point out that if this is urgent, you really should have logged this as a case with support.cadence.com; these forums are community forums - folks (including those from Cadence) respond in their spare time and it should not be seen as a substitute for formal customer support.
    That said, thanks to Quek for being so diligent with these questions!
  • Supriyo
    Supriyo over 8 years ago in reply to Andrew Beckett
    Hi Andrew and Quek,
    Please know that I more than appreciate the help cadence community is giving out voluntarily so that users don't have to go through a more time consuming official process of filing a ticket. I just wanted to be sure that Quek knows the problem. I would like to have the solution early but there is absolutely no urgency.
    Thanks again.
    Regards
    Supriyo
  • Quek
    Quek over 8 years ago in reply to Supriyo
    Hi Supriyo
    The problem was that the instance parameters got lost after ciExpandMembers. You can use the following as a workaround:
    procedure( CCSciExpandMembers(memberList)
       prog( (finalList memName memType instList2)
          finalList=foreach(mapcar member memberList
             memName=nth(0 member)
             memType=nth(1 member)
             instList2=foreach(mapcar instList ciExpandMembers(list(list(memName memType)))
                append(instList cddr(member))
             ) ;foreach
             car(instList2)
          ) ;foreach
          return(finalList)
       ) ;prog
    ) ;procedure
    cvLay=geGetWindowCellView()
    cache=ciCacheGet(cvLay~>libName cvLay~>cellName "layout")
    memberList=list(
       list("I6" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
       list("I7" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
    ) ;list
    modgen=ciConCreate(cache 'modgen
            ?members CCSciExpandMembers(memberList)
    ) ;ciConCreate
    May we have your help to file a case to fix the behaviour of ciExpandMembers? I think it should preserve the instance parameters. You can use the following example in the case:
    ciExpandMembers(list(list("I6" 'inst list('("row" 0)))))
    => (("I6" inst))
    Best regards
    Quek
  • Supriyo
    Supriyo over 8 years ago in reply to Quek
    Thanks Quek, workaround works. Please let me know the process to file a case. However, I am not sure how to declare a pattern like ‘A B B A’. Abutment does not work for the example below.
               memberList=list(
               list("|T5(1)" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
               list("|T4(1)" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
               list("|T5(2)" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
               list("|T4(2)" 'inst list('("row" 0) '("col" 0) '("abutment" 1)))
               ) ;list
                modgen=ciConCreate(cache 'modgen ?members CCSciExpandMembers(memberList)
    ) ;ciConCreate
                ;;mgAbutAllCB()
                mgGen( cvLay modgen )
    Earlier I used pattern param inside ciExpandMembers as follows
                modgen=ciConCreate(cache 'modgen ?members ciExpandMembers(memberList) ?params list(list( "numRows" 1 ) list( "numCols" 1) list("pattern" "custom ((A B B A))")
            ) ;list
    ) ;ciConCreate
    It also worked from the gui.
    Regards
    Supriyo
  • Quek
    Hi Supriyo
    Using custom pattern "A B B A" is also ok. You just need to change numCols from 1 to 4.
            ?params list(
               list("numRows" 1)
               list("numCols" 4)
            ) ;list
    ) ;ciConCreate
    You can file a case as follows:
    a. Go to "https://support.cadence.com"
    b. At the top of the page, choose "Cases->Submit Cases" from the menu
    c. Choose "Virtuoso Layout Suite" as the product and in the subsequent page, choose "IC6.1.7" as the version
    d. Please use the following problem description:
    ciExpandMembers SKILL cmd does not preserve the instance parameters as shown below:
    ciExpandMembers(list(list("I6<0:1>" 'inst list('("row" 0)))))
    => (("I6<0>" inst) ("I6<1>" inst))
    Please help to file a CCR to either fix (if it is a bug) or to enhance it to preserve instance parameters. The expected output is as follows:
    (("I6<0>" inst list('("row" 0))) ("I6<1>" inst) list('("row" 0)))
    Best regards
    Quek
  • Supriyo
    Thanks Quek,
    Changing the numCols from 1 to 4 had no effect and abutment did not work. What I realized is that list("pattern" "custom ((A B B A))") was not working as ciConCreate defined the pattern always based on the sequence instances were added to the memberList. And since my memberList was implicitly defining a pattern like A B A B which is not a valid pattern (without rotation), abutment was not successful.
    Anyway I understand the problem now. I think ciConCreate should accept the pattern (as well as rotation, also seems to be not working) as argument, not sure if this is a bug.
    While filing a case, it asked for a host id which I obtained by running the command lmhostid as suggested. But the key was not accepted. I am not sure if I am the right person. Please let me know if I should contact the university Professor who is acting as liaison officer.
    Regards
    Supriyo
  • Quek
    Hi Supriyo
    This is strange. Changing numCols from 1 to 4 works for me. Would you please try IC617 and let us know if you are able to get the abutment?
    it is ok not to contact the university professor. I will file the request to R&D.
    Best regards
    Quek
  • Supriyo
    Hi Quek,
    I quickly checked IC617, looks like not working. Infact there was undefined function error with mgGen. Most likely it has been phased out as you also said before. I observed that it did not even enclose the interdigitated devices together which is a step before abutment occurs. It worked fine from gui. The skill code is as follows.
               memberList=list(
               ) ;list
            ?params list(
                list("numRows" 1)
                list("numCols" 4)
            ) ;list
    ) ;ciConCreate
    One thing to note, it makes sense that pattern definition comes from memberList since nowhere we are mapping transistor names to ‘A’ ‘B’ before we pass the arguments in ciConCreate. But not sure if I am missing out something.
    Regards
    Supriyo
  • Quek
    Hi Supriyo
    Would you please help to do the following and provide the output of the cmds?
    a. Select the 4 instances in your layout
    b. Execute the following cmds in CIW:
    geGetSelSet()~>name
    geGetSelSet()~>instTerms~>net~>name
    getVersion('subVer)
    c. Please kindly provide a snapshot of your current result for the 4 instances
    Best regards
    Quek
  • Supriyo
    Hi Quek,
    Please see the attachment. The image is slightly poor in quality since had to meet recommended size limit.
    Regards
    Supriyo
