  3. skill command for layout execution
  • Replies 26
  • Subscribers 152
  • Views 39861
Supriyo
Supriyo over 8 years ago
I am trying to get familiar with skill by following commands printed on CIW. There are few layout related questions on that.
1)  These are the set of commands that get printed when I execute “generate all from source” from virtuoso layout editor.
        lxHiReInitDesign()
        hiiSetCurrentForm('lxTemplateForm)
        lxTemplateForm->templateTab->page1->pMinSep->value=1.0
        hiFormDone(lxTemplateForm)
When I execute them in skill file, the interactive window appears and asks for user input. How do I pass the user input in the skill file itself as function argument.
2) For the interdigitization, I see set of commands get executed when modGen is called, some of them are shown below. But the same commands fail to work from skill. What function call with arguments should I use to interdigitate for example two transistors with 2 fingers each with a pattern ABBA.
mgCreateOrEdit(geGetEditCellView() “nil” “nil")
mgPatternCB()
hiiSetCurrentForm('patternForm)
patternForm->g_patternRadio->value= "Customize"
hiFormDone(patternForm)
mgAbutAllCB()
3) I am calling chip level routing assembly from skill the following way.
        ipcBeginProcess("/package/eda/cadence/IC616/tools/iccraft/bin/vcar -lib tutorial -cell amplifierDemo -view layout.routed.routed  -constraintGroup virtuosoDefaultSetup  -protectPreRoutes  -o router_01-31-2018_17:13:26.log”)
When I execute detailed routing on the new window, I do not see any command appearing on CIW, may be because the routing tool runs independent from virtuoso. What function call would be involved after the command above to run detailed routing with say 25 passes. I am guessing same problem would occur while invoking calibre drc, lvs and then passing arguments on them.
Regards
Supriyo
  • Quek
    Quek over 8 years ago in reply to Supriyo
    Hi Supriyo
    Let me reproduce the info here:
    name:
    T5(1) : net06, net06, VDD
    T5(2) : net06, net06, VDD
    T4(1) : net06, net012, VDD
    T4(2) : net06, net012, VDD
    Your are using IC616-500-1.
    Would you also please provide the following info?
    a. geGetSelSet()~>instTerms~>name
    b. Switch to IC617 and execute the following:
    getVersion( 'subVer )
    Best regards
    Quek
  • Supriyo
    Supriyo over 8 years ago in reply to Quek
    Please see the result
    a)
    (("g" "d" "s")
        ("g" "d" "s")
        ("g" "d" "s")
        ("g" "d" "s")
    b)
    "sub-version  IC6.1.7-64b.500.14 "
    Regards
    Supriyo
  • Quek
    Hi Supriyo
    Would you please try the following?
    a. Please use IC617-500-14 instead of IC616-500-1? Your version of IC616 is too outdated
    b. There does seem to be a problem with the custom pattern. Even though my instances can be abutted, the pattern is wrong. It happens even if I add orient and mapping info:
    modgen=ciConCreate(cache 'modgen
            ?members CCSciExpandMembers(memberList)
            ?params list(
               list("numRows" 1)
               list("numCols" 4)
               list("pattern" "custom ((A B B A)) ((MY R0 MY R0)) mapping ( (T5 A) (T4 B) )")
            ) ;list
    ) ;ciConCreate
    I have filed CCR1878108 to check with R&D on this issue.
    c. You can use this as a workaround. I have modified the instance parameters to force modgen to create a correct pattern:
    memberList=list(
       list("T5(1)" 'inst list('("row" 0) '("col" 0) '("abutment" 1) '("orient" "MY")))
       list("T4(1)" 'inst list('("row" 0) '("col" 1) '("abutment" 1) '("orient" "R0")))
       list("T4(2)" 'inst list('("row" 0) '("col" 2) '("abutment" 1) '("orient" "MY")))
       list("T5(2)" 'inst list('("row" 0) '("col" 3) '("abutment" 1) '("orient" "R0")))
    ) ;list
            ?params list(
               list("numRows" 1)
               list("numCols" 4)
            ) ;list
    ) ;ciConCreate
    By the way, ciExpandMembers will be able to preserve instance parameters in the upcoming IC618 release.
    Best regards
    Quek
  • Supriyo
    Thanks Quek. It seems like the workaround does not work for IC617. Please see the screenshot. However, with what we have figured out so far, I do have a workaround in IC616. Also I have become a bit more familiar with the environment :), would like to continue till 618 comes in perhaps.
    Regards
    Supriyo
  • Quek
    Hi Supriyo
    This is just for your info. R&D has suggested using gpe* cmds to resolve the placement problem. Here are the cmds:
    a. Select the instances in the layout
    b. Enter the following cmds in CIW:
    sbox=gpeCreateSandbox( ?sync t)
    gpeSetMap(sbox list(list("T5" "X") list("T4" "Y")))
    gpeSetGrid(sbox list(list("X" "Y" "Y" "X")))
    Please refer to $CDSHOME/doc/sklayoutref/sklayoutref.pdf for more details on gpe* cmds.
    Best regards
    Quek
  • Supriyo
    Hi Quek,
    Thanks for getting back. I will try this out later in the week.
    Regards
    Supriyo
