  3. search list and return the match list
  • Subscribers 150
  • Views 20288
wenckey
wenckey over 7 years ago
The case is like below:
I have two list like
LIST1= list("at" "ad" "ap")
LIST2=list("dad" "bad" "god" "dog" map" "lap" "glad")
What I want to do is search the LIST2 with the key word listed in LIST1, if match , ADD the match item to the new list LIST3
so for this case , the return value should be LIST3=("dad" "bad" "map" )
Anyone can give some advise or share the code?
Kevin
  • Quek
    Quek over 7 years ago
    Hi Kevin
    The following code should be ok:
    procedure( CCSflattenList(myList)
       if(listp(myList)
          mapcan('CCSflattenList myList)
          list(myList)
       ) ;if
    ) ;procedure CCSflattenList from solution 11023690
    myList1= list("at" "ad" "ap")
    myList2=list("dad" "bad" "god" "dog" "map" "lap" "glad")
    procedure( CCSgetMatchedItems(myList1 myList2)
       prog( (myList3 myList3Flat myList3Final)
          myList3=foreach( mapcar x myList1
             pcreMatchList(x myList2)
          ) ;foreach
          myList3Flat=CCSflattenList(myList3)
          myList3Final=list()
          foreach( x myList3Flat
             unless( member(x myList3Final)
                myList3Final=append1(myList3Final x)
             ) ;unless
          ) ;foreach
          return(myList3Final)
       ) ;prog
    ) ;procedure
    Best regards
    Quek
    Andrew Beckett over 7 years ago in reply to Quek
    Quek, sorry to point out that this can be done rather more concisely:
    LIST3=setof(elem LIST2
      exists(pat LIST1 index(elem pat))
    this returns:
    ("dad" "bad" "map" "lap" "glad")
    Which isn't quite the same as your suggested return value (same contents as Quek's but in a different order). I think Kevin's suggestion as to the value of LIST3 has an error, unless there is some other criteria for match that you (Kevin) has not made clear.
  • Quek
    Quek over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    This is awesome. : )  Thank you very much. I have learned a lot from your example.
    Best regards
    Quek
