  3. How to properly handle wave family in custom calculator...
  • Views 19930
How to properly handle wave family in custom calculator function
alexstepanov75
alexstepanov75 over 8 years ago
I needed a function that will resample waveform using points from another waveform.
So I wrote function below:
;Function to resample sourceWave by points from pointsWave
;sourceWave waveform to be resamled
;pointsWave from this waveform points taken to resample sourceWave
procedure( resampleByWave(sourceWave pointsWave)
let( (xVec yVec wave yFactor numOfPoints thisX sweepVal i sweepName sweepValues currentSourceWave currentPointsWave sweepValType)
cond(
(drIsWaveform(sourceWave)
;printf("%L\n" sourceWave->??)
wave=drCreateEmptyWaveform()
xVec=drGetWaveformXVec(pointsWave);x vector created from pointsWave
numOfPoints=drVectorLength(xVec)
yVec=drCreateVec(drType(drGetWaveformYVec(sourceWave)) numOfPoints);empty y vector
for( i 0 sub1(numOfPoints);for each point from pointsWave
thisX=drGetElem(xVec i);x value
currentValue=value(sourceWave thisX );y value from sourceWave corresponding to x value from pointsWave
drAddElem(yVec currentValue);add y element
);for
drPutWaveformXVec(wave xVec)
drPutWaveformYVec(wave yVec)
wave~>leafSignalTypeName=sourceWave~>leafSignalTypeName
wave~>leafDataSet=sourceWave~>leafDataSet
wave~>leafAnalysisType=sourceWave~>leafAnalysisType
);drIsWaveform(sourceWave)
(famIsFamily(sourceWave)
sweepName=famGetSweepName(sourceWave)
sweepValues=famGetSweepValues(sourceWave)
sweepValType=type(car(sweepValues))
case(sweepValType
('fixnum wave=famCreateFamily(sweepName 'intlong))
('flonum wave=famCreateFamily(sweepName 'float))
('string wave=famCreateFamily(sweepName 'string))
(t error("resampleByWave: unable to understand type %L\n" sweepValType))
);case
foreach( sweepVal sweepValues
currentSourceWave=famValue(sourceWave sweepVal)
currentPointsWave=famValue(pointsWave sweepVal)
famAddValue(wave sweepVal resampleByWave(currentSourceWave currentPointsWave ))
);foreach
);famIsFamily(sourceWave)
(t
error("resampleByWave: invalid waveform %L\n" sourceWave)
);t
);cond
wave
);let
);proc
I am not sure about a case when input waveforms are family of plots. Is this part of the code correct?
    Your code is unnecessarily complicated in the famIsFamily branch. You should just be able to do:
      famMap('resampleByWave sourceWave pointsWave)
    This takes care of iterating through the families (you could have families, or families of families, or families of families of families - etc) and then applying the resampleByWave to the layer beneath and reconstructing the curves or families from that.
    Note, I didn't test your code (lack of indentation made it hard to read too); my suggestion is however the way I do this all the time.
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago in reply to Andrew Beckett
    By the way, a similar approach is necessary for any custom function in order to work in ADE XL with sweeps, corners, and Monte Carlo (see https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20467133).
    Andrew Beckett over 8 years ago in reply to Frank Wiedmann
    There are also plenty of examples in the Custom IC Calculator SKILL Function Library (there will be more as I update a number of my articles on Cadence Online Support to use the new calculator GUI template that was introduced in IC617).
  • alexstepanov75
    alexstepanov75 over 8 years ago in reply to Andrew Beckett
    Andrew,
    Thank you for replay. I have two additional questions:
    1. I saw examples of famMap usage like you described. I checked manual for function famMap. It says "Applies a function with a set of arguments to each member of a family". It is not clear if an argument can be family too. In my case, pointsWave can be family of plots exactly like sourceWave, and resampleByWave should be applied to appropriate pairs. So will famMap work properly if used like you proposed?
    2. How can I copy past code with indentation? I tried a couple of formattings but in each case spaces at the beginning of line removed.
    Alex.
    Andrew Beckett over 8 years ago in reply to alexstepanov75
    Alex,
    Yes, famMap will iterate over families in all the arguments together, so it will work pair-wise as you desire.
    The second question I can't really answer, as it almost certainly depends on what platform you're running your web browser on and which browser you're using. I use Mac and Safari (mostly) and Chrome (occasionally). I do from time to time have problems with preserving indentation - but I've not really done an exhaustive analysis of what works when (it has changed over time with different versions of the forum software too).
  • Curtisma
    Curtisma over 8 years ago in reply to Andrew Beckett
    I have had luck using the <pre> tag by going to tools-> source code.  I think you could also do this by selecting the block -> pre formatting option.  Then I just copy in my code with tabs.
