  3. PhysConfig: force to descend
  • Views 15702
WTony
WTony over 8 years ago
How can I set an instance to "force to descend" in skill. so during the "Gen from source", it will generate the sub layout of that instance.
    That would be cphSetInstForceDescend. You'd need to have an open physConfig (e.g. using cphFindOpenConfig or cphOpenConfig). There are also APIs to set force descend on cells and occurrences too.
    Search for any function that begins with "cph" in cdsFinder and then you can hit the "More Info" button (in IC617/ICADV122 onwards) to take you to the full documentation for the function.
