  3. residual cdf parameters after switching lib
  • Subscribers 150
  • Views 16738
DavidLou
DavidLou over 8 years ago
hi exports,
I have a question about cadence. say we have two sets of libraries. libA has full set parameters for the cells while libB has less parameters for the same cells.
once the design switched from libA to libB, the instances in the schematic would keep obsolete parameters from libA, even it's now associated with libB.
how can we easily flush the obsolete parameters out (although I know I can always manually replace all the instances from the new lib).
thanks,
David
  • Quek
    Quek over 8 years ago
    Hi David
    I think this can be quite easily done using a SKILL script. E.g.
    procedure( CCSremoveParams(lib)
       let( (cv)
          foreach( cell ddGetObj(lib)~>cells
             foreach( view setof(x cell~>views pcreMatchp("schematic" x~>name)
                cv=dbOpenCellViewByType(lib cell~>name view~>name "" "a")
                ;;; do something ;;;
                schCheck(cv)
                dbSave(cv)
                dbClose(cv)
             ) ;foreach
          ) ;foreach
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • DavidLou
    DavidLou over 8 years ago in reply to Quek
    thanks Quek,
    This seems to generate sub-lib from existing library by removing specific parameters. that's not what I want. we've already had such sub-lib. but when the schematic design updated to attach new lib, the instances in the schematic would keep past parameters, not automatically updated to have only parameters from the new library. so what I want is to remove obsolete parameters from the instances.
    would there be easy way for that?
    thanks,
    David
  • Quek
    Quek over 8 years ago in reply to DavidLou
    Hi David
    I am not sure if this can resolve your problem, hope that it will be helpful:
    procedure( CCSremoveParams(newLib)
       let( (cv cdfTable techLib baseCdf instCdf paramList)
          cdfTable=makeTable("cdfTable" nil)
          techLib=techGetTechFile(ddGetObj(newLib))~>libName
          foreach( cell ddGetObj(techLib)~>cells
             baseCdf=cdfGetBaseCellCDF(cell)
             cdfTable[cell~>name]=foreach(mapcar x baseCdf->parameters x->name)
          ) ;foreach
          foreach( cell ddGetObj(newLib)~>cells
                cv=dbOpenCellViewByType(newLib cell~>name view~>name "" "a")
                foreach( inst setof(x cv~>instances x~>libName==techLib)
                   instCdf=cdfGetInstCDF(inst)
                   paramList=setof(x instCdf->parameters !member(x->name cdfTable[cell~>name]]))
                   apply('cdfDeleteParam paramList)
                ) ;foreach
                schCheck(cv)
                dbSave(cv)
                dbClose(cv)
             ) ;foreach
          ) ;foreach
       ) ;let
    ) ;procedure
    If it is not what you need, perhaps it might be best to file a case so that the local AE can assist you on the problem.
    Best regards
    Quek
