  3. get & set Ade -L session field values
  • Subscribers 148
  • Views 1971
mlea
mlea over 8 years ago
Hi ,
Im trying to get the value of the AdE-L -> outputs- > save ALL -> select signals to output (save) field.
 if the value is not "selected", I need to set it to that value .
since this is not a analysis parameter  ( it is a session parameter ) I'm doing:
pp_session= asiGetCurrentSession()
if( pp_asiSession~>data~>env~>data~>outputs~>data~>save~>value != "selected" then ...
the problem is that I know it is possible to do it differently , Ain a much more easy ( and correct) methode. I also need to set the new field value .
 probably using the command  :  asiGetFormFieldVal(r_form s_fieldName) .
any advise?
Meny
    Meny,
    asiGetKeepOptionVal(asiGetCurrentSession() 'save)
    asiSetKeepOptionVal(asiGetCurrentSession() 'save "selected")
  • mlea
    mlea over 8 years ago in reply to Andrew Beckett
    andrew
    thank you. it works.
    by thew way - the finder doc utility of ICADV12.3 is indeed much more helpful than IC616, but on the "more info" sectio is would be very recommended if the example would contaib . the minimu information for such command such as asiGetFormFieldVal or asiGetKeepOptionVal : a user that isn't familier with the different options cant really take advantage of the example.
    Andrew Beckett over 8 years ago in reply to mlea
    Hi Meny,
    The documentation itself hasn't changed - what's new is that the Finder now takes you to the documentation for the function.
    The main challenge is that the documentation was created many years ago, and is really written with the developer of the simulation integration in mind, who is likely to know what a "keep option" is. I completely agree that the documentation is not detailed enough and the examples are not particularly useful in this manual. The only thing I can suggest is that you log a case with customer support requesting that this specific manual be improved - showing why you think it's insufficient (a real user asking this has more priority than me asking for it).
  • mlea
    agree. i will file a SR.
    thx
