  3. How to convert GDS file in to a readable file.
  • Subscribers 150
  • Views 32389
skillEater
skillEater over 8 years ago
When we export GDS in icfb  it will export an compressed file which we cant read .
Is there any way to export GDS which can be readable or to convert a compressed GDS to readable GDS.
I tried to decompress using all decmpression commands. But nothing is working out.
Ganesh Doddipatla.
    Ganesh,
    The File->Export->Stream interface does allow the stream (GDS) file to be compressed - if you're talking about IC5141, then there's an option on the form:
    In IC617 (for example) you just put .gz on the end of the filename. However, I suspect you're not using compression at all - because if  you pick "none" (or in IC617 don't use the .gz suffix) it won't be compressed. The stream file however is binary. It's not compressed - but you won't be able to read it as plain text. There's no such thing as ASCII (text) stream format. The closest you have in IC5141 is the "ASCII Dump" option on the form (this doesn't exist in IC617) but that won't be readable in any other tool.
    So, to summarize, there's no such format as "readable GDS" - it's inherently a binary format.
  • Quek
    Quek over 8 years ago
    Hi Ganesh
    You can convert a binary gds file back to ascii format using either of the following methods:
    a. If you are using IC5141, I think there is already an option in the stream-out form to export the layout as an ascii file
    b. Use a perl script together with gds2 module
    c. Open the gds file using Cadence's gds viewer Quickview and export it as an ascii file
    Best regards
    Quek
  • Quek
    Quek over 8 years ago in reply to Quek
    haha, Andrew is still faster than me. : )
    Andrew Beckett over 8 years ago in reply to Quek
    This time ;-)
    However, those were good additional suggestions too, Quek!
  • skillEater
    skillEater over 8 years ago in reply to Andrew Beckett
    Hi Andrew & Quek ,
    Thanks for the suggestions.
    As Andrew suspected it is a binary file for sure.So, I converted this in to ASCII file by using command base64.
    It is converted as ASCII file. I checked it by using command file.
    But after that I felt that it is also encrypted too.Because the text is still not readable.
    So, can anyone tell me the wrong I did.
    FYI I am using ICADV12.2.
    Ganesh Doddipatla.
    Andrew Beckett over 8 years ago in reply to skillEater
    Ganesh,
    I didn't suspect it was a binary file. It absolutely is a binary file. The precise format is described in Appendix A of the Design Data Translator's Reference (i.e. <ICinstDir>/doc/transrefOA/transrefOA.pdf if you want the PDF rather than using cdnshelp).
    I have no idea why you think that using base64 would magically make a binary file readable. All it does is encode the input file to use an ASCII character set. It cannot make a structured binary file somehow readable. The data is not encrypted - it's just a binary representation that stores records for shapes, coordinates, structures and so on.
    As Quek suggested, the Quickview tool (k2_viewer) can read a stream (a.k.a. GDS) file and then you can use Tools->ASCII Export/Import to write it out to a readable text file. This produces a readable representation of the data that's in the file - for example (a partial dump):
    // Dump of adc_interpolator.gds (262144 bytes)
    // Width, extension and XY coordinates are divided by DBU Scale.
    // DBU Scale: 2.000e+03
    HEADER: 5
    BGNLIB: // At 6
        July 8 113 11:22:24, July 8 113 12:01:12
    LIBNAME: opamp090
    UNITS: 5.0000000000000001e-04, 5.0000000000000003e-10
    BGNSTR: // At 66
        July 8 113 12:01:12, Jan 1 70 1:00:00
    STRNAME: M2_M1_CDNS_373281272760
    BOUNDARY: // At 122
    LAYER: 8
    DATATYPE: 0
    XY:
         -0.0700, -0.0700
         0.0700, -0.0700
         0.0700, 0.0700
         -0.0700, 0.0700
         -0.0700, -0.0700
    ENDEL
    BOUNDARY: // At 186
    LAYER: 7
    DATATYPE: 0
    XY:
         -0.1300, -0.1300
         0.1300, -0.1300
         0.1300, 0.1300
         -0.1300, 0.1300
         -0.1300, -0.1300
    ENDEL
    BOUNDARY: // At 250
    LAYER: 9
    DATATYPE: 0
    XY:
         -0.1300, -0.1300
         0.1300, -0.1300
         0.1300, 0.1300
         -0.1300, 0.1300
         -0.1300, -0.1300
    ENDEL
    ENDSTR
    BGNSTR: // At 318
    STRNAME: M2_M1_CDNS_373281272761
    BOUNDARY: // At 374
    LAYER: 8
    DATATYPE: 0
    XY:
         0.1000, 0.2700
         0.2400, 0.2700
         0.2400, 0.4100
         0.1000, 0.4100
         0.1000, 0.2700
    ENDEL
    As I said before, this is not a standardised format, and other tools will not read it. However, if you compare the record names in the append you'll see they match the contents of this ASCII dump.
