  3. port layout for different metal stacks
  • Views 16574
ajni
ajni over 8 years ago
Hi all
I am working on a layout design which needs a present layout to be ported to another  lower metal stack.
when i open the present layout which is at higher metal stack in lower metal stack library , the layers which are not common are dropped.
How do we port layout if if have such requirement.
I am planning to have script for this.
Has anybody worked on this earlier.
Regards
vinutha
    Andrew Beckett over 8 years ago +1
    Hi Vinutha, Note that the layers are not "dropped". The data is still in the database - it's just that you can't see it because the layer-purpose pairs are not defined in the technology library. In the…
    Hi Vinutha,
    Note that the layers are not "dropped". The data is still in the database - it's just that you can't see it because the layer-purpose pairs are not defined in the technology library. In the actual database, the shapes are stored using the layer and purpose numbers - so you'd still find them using the original layer number and purpose numbers - so you can still find those shapes and move them onto a different layer-purpose (if necessary) or delete them if you really don't want them (for example).
  • ajni
    ajni over 8 years ago in reply to Andrew Beckett
    thanks Andrew.
