  3. adexl calculator skill function to find string
  • Views 14942
Pedro P
Pedro P over 8 years ago
I am running ams simulations (RTL + Verilog-a + schematic) , where I use some the $display functions to dump into the irun.log debug information about my simulation tests.
I am running this simulation on adexl and I would like to be able to have a skill function that I could use in the adexl calculator, to get a pass or a fail if some string is found in the irun.log.
Example, if in the irun.log there is a string “my test A = pass” then I would like to have a skill function that find how many times the string was found in the irun.log, such that I could use this to check if my test have passed and how many times this string was found in the irun.log .
Is this possible?  I thought that I would have to use the pcre function.
Could you help me with this skill code?
    This article on Cadence Online Support may help...
  • Pedro P
    Pedro P over 8 years ago in reply to Andrew Beckett
    Thank you for your help. This is exactly what I was searching for.
