  3. Montecarlo simulation with Verilog-A and Python
  • Subscribers 150
  • Views 18297
farhan89
farhan89 over 8 years ago
Hi All,
I have a Verilog-A model of a transistor and now I am extending it for variability modeling. Currently I have a test variability model in Python that uses some libraries to generate results for Montecarlo simulation (using transistor model in python language). Now, I would like to convert the complete model in to Verilog-A compatible format. I have read Verilog-A manual and what I have understood is that I have to write a statistical block to run Montecarlo simulation (by generating samples for each simulation run). For that, I have few questions:
1. Can I call python code from Verilog-A or Statistical block to generate a model parameters sample from my python code and then run simulation using spectre simulator with python generated samples?
2. Can I define Joint PDF (means and co-variances matrix) in statistical block?
I am using Cadence IC 6.1.6 and MMSIM 14.10.
Farhan
    Andrew Beckett over 8 years ago +1
    Farhan, For the first question, the answer is really no. You can potentially use DPI-C mechanism (see the section header "Calling functions implemented in C" in the Cadence Verilog-A reference manual…
    Farhan,
    For the first question, the answer is really no. You can potentially use DPI-C mechanism (see the section header "Calling functions implemented in C" in the Cadence Verilog-A reference manual), but even then that would be to just do some of the computation in the  model. The statistically varied parameters would come from the statistics block - you could of course then transform them in some what to whatever distribution  you wanted to use within your mode. You can't call python directly from Verilog-A and you can't call it to generate the samples in the statistics block.
    I'm not sure about the second question. You can define as many independent statistical variables as you like, and then the response would be based on the influence of those independent variables based on what the models (and circuit) does with them. So you'd end up with a joint PDF anyway. You can also define correlation coefficients between these statistical variables so they don't have to be completely uncorrelated either.
  • farhan89
    farhan89 over 8 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for the explanation.
    I have read the ADE XL manual and found our that I can define model files as parameters as well. So, I think another work around would be to implement a custom menu in ADE-XL environment that checks for the Montecarlo parameters (specifically number of points/samples) and using this custom implemented menu I generate as many models (with varying model parameters) as defined in Montecarlo samples. Then I run my simulation by iterating over each model. In the end the flow would be:
    - Include model libraries as parameterized model i.e. VAR("myModelFile")
    - Set Montecarlo Parameters (X samples/ Points)
    - Generate X models using SKILL - Python
    - Run simulation by iterating over python generated model files
    What do you think?. Will this approach work?
    Farhan
    Andrew Beckett over 8 years ago in reply to farhan89
    I doubt it. It's going to be a lot of work (and is horribly complicated) and it's not obvious what benefit running Monte Carlo gives over a normal sweep. I'd certainly not do it that way and I'm pretty au fait with the inner workings of ADE XL.
  • drdanmc
    drdanmc over 8 years ago
    Taking the normal random variables as an example, in spectre you specify a standard deviation and it gives you a zero mean, independently distributed variable.  But you can decompose a set of random variables with different means and a co-variance matrix into sums of independent, zero mean random variables.  I.e.
    y = Ax + b
    where x are your zero mean, unit variance random variables, A is a matrix that transforms to give the desired variances and co-variances, and b is a vector of means.
    -Dan
