  3. how to identify spectre simulator version from SKILL?
  • Views 16744
marcelpreda
marcelpreda over 8 years ago
Hi there,
How can I identify the version of spectre simulator ?
IC version >= 6.1.5
Assumption is the simulator is sent (session loaded in ADE-L).
The only thing that I have in mind is to call the external command "spectre -W" and to parse the output.
BR,
Marcel
    Hi Marcel,
    I don't think there's any public (or even private) function that provides that. Most of the stuff in ADE that is version-specific uses a capability called "feature files" which are picked up from the spectre/AMS simulators that are in the path, and then use that to determine whether particular features in the simulators are available or not - so they don't need to know version numbers.
    So probably using the approach you suggest is the sensible option.
