  3. Generating shapes of overlap of two layers within multiple...
  • Subscribers 150
  • Views 20023
Generating shapes of overlap of two layers within multiple hierarchies
Quincy
Quincy over 8 years ago
Hi Everybody,
I am trying to generate shapes that are the overlap of two layers in a layout cellview.  The cellview could contain additional levels where I would have to bring those shapes up to the top cellview.
My question is how do I bring up and transform the objects from the lower hierarchies up to the top cellivew to be manipulated by dbLayerAnd.
My idea is to:
1) Identify interested shapes at multiple hierarchies using dbShapeQuery or dbGetOverlaps
2) Extract the transform property from the shape or objects using dbGetHierPathTransform or looking up the transform attribute with the '~>' operator
3) Copy interested shapes from all hierarchies to two temporary layers at the top cellview using dbCopyFig
4) Do dbLayerAnd of the two temporary layers to make another temporary layer at the top cellview
5) Clear temporary layers generated in step 3
I am trying to implement steps 2 and 3 at the moment.  dbGetHierPathTransform appears to be giving me not what I am expecting, however dbGetOverlaps(cv bBox lpp 32)~>transform is giving me a nested list of the right transforms.  I am working on how to take the transform information and passing it to dbCopyFig such that I can execute step 4.
Any help or tips would be greatly appreciated.
This post had promising information, but I wasn't able to follow as I am not very proficient in SKILL.
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/24935/how-to-use-hierarchy-objects-in-dblayersize-command/1319510#1319510
Quincy
  • RK56
    RK56 over 8 years ago
    Hi Quincy,
    Try abe* functions (ABE => Advanced Boolean Engine)
    -Ramakrishnan
  • TaherEssam
    TaherEssam over 8 years ago
    Quincy,
    Consider a top cell top_cell, a sub cell sub_cell, and object to be copied id_obj (the outcome of dbGetOverlaps() )
    Copying figure from sub_cell to top_cell can be done as follows:
    cv_sub = dbOpenCellViewByType( 'LibraryName 'sub_cell "layout" "maskLayout" "r" )
    cv_top = dbOpenCellViewByType( 'LibraryName 'top_cell "layout" "maskLayout" "r" )
    id_obj = dbGetOverlaps(cv_sub bBox lpp 32)
    dbCopyFig(top_cell id_obj list(dx:dy "R0" 1.0) )
    if you want to have them exactly on top of copied object in sub_cell, then dx:dy is 0:0
    Taher.
  • TaherEssam
    TaherEssam over 8 years ago in reply to TaherEssam
    should be dbCopyFig(id_obj top_cell list(dx:dy "R0" 1.0) )
    Taher.
    Andrew Beckett over 8 years ago in reply to TaherEssam
    Taher,
    Er, that won't work. The output of dbGetOverlaps is a list of objects or a list of lists - with information about the hierarchical path down to each object. You'd have to:
    • Loop over this list to copy each object using each piece of "overlap" data.
    • Work out the overall transformation - using dbGetHierPathTransform for example - you've just used a fixed transformation which won't be correct if there is more than one level of hierarchy, or rotation.
    • Get the leaf object from the "overlap" info - fairly easy to find .
    • Then dbCopyFig that with the overall transformation (for each "overlap").
    Using the abe functions is easier than all of this, so if you have access to an IC617/ICADV123 release (ideally probably later than ISR5-6 - there were some issues with the "abe" functions in early IC617/ICADV122 versions which resulted in a change of the how the arguments are passed).
  • Quincy
    Hey Everybody,
    Thank you for the input everyone.  Sorry for the late update, I was able to get my script working but got bogged done with adding features.  My version of Cadence is 6.1.6 so I unfortunately did not have abe functions.  Anyhow the solution is in the link I posted in my original post, it just took me some time understanding how it worked.  The idea is that your initial data is a hierarchical list of all the shapes you are interested in but need to get them in a flattened list.  You have to return all the leaf nodes, the shapes, in the list using a recursive function which is shown in the link.  And every time a leaf is returned you have to take the transformation from that shape you returned and copy a new shape at your top level with that transformation.  Anyhow everything that one would need to flatten a hierarchical list of shapes is in the link in my original post.  The input argument is a hierarchical list of shapes and the output is a new flattened list of those shapes.  In my script, I ended up using a temporary layer for the flattened list of shapes for calculations and deleted them upon completion.
    For those that are interested, myself included, there is a function called rtegeom that looks interesting if you don't have the abe functions.
    Thanks everyone for your time and input.
    Quincy
