  3. Is there any procedure similar with atof(), but to consider...
  • Views 15797
Is there any procedure similar with atof(), but to consider scaling factor?
marcelpreda
marcelpreda over 8 years ago
Hi there,
Is there any procedure similar with atof() but to consider the scaling factors (u, m, k, M, G...)
I'm reading some data from text files, and where are floating numbers there could be also scaling/multiplicity factor.
Using atof() is ignoring the scaling factor, the only solution seems to be evalstring(). But I don't like it too much , because I don't know what other code could be executed.
So, is there something similar with atof(), but to consider those scaling factors?
What I mean:
numAsStr = "1.7m"
atof(numAsStr) => 1.7
evalstring(numAsStr) => 0.0017
BR,
Marcel
    Marcel,
    cdfParseFloatString() is a good choice for this.
    I'm happy that you don't like using evalstring for this - that's certainly bad practice, as you might unwittingly execute all sorts of code accidentally. I always give the example of a user accidentally entering "exit()" in a field that ends up being evaluated using evalstring...
  • marcelpreda
    marcelpreda over 8 years ago in reply to Andrew Beckett
    Thank you.
    Just tested, it works.
    Next question: cdfParseFloatString() is available by default, or a certain context has to be loaded ?
    Best Regards,
    Marcel
    Andrew Beckett over 8 years ago in reply to marcelpreda
    Hi Marcel,
    It's a pcell-safe function (so that means you can use it in all executables, including dbAccess. Not in the "skill" executable though, but I doubt that matters!). Also it's a binary function, so doesn't require a context to be loaded.
