  3. I'd like to get checksum of a cell view layout. Is there...
  • Subscribers 150
  • Views 2732
I'd like to get checksum of a cell view layout. Is there a built-in function in Cadence to do this?
acowan
acowan over 8 years ago
I'd like to get SHA hash (checksum) of a cell view layout.  Is there a built-in function in Cadence to do this?
Long explanation:  What I need is a way to compare two layouts in a very compute and time efficient manner.  If I had a SHA256 hash that compressed all the shapes, text, properties, etc... of a layout I could use the SHA hash key to compare layouts.  This could tell me if a layout view changed over time (it won't tell what changed - just THAT it changed).
The cell view layout is in the end just an object... so this seems doable by extracting key fields of the layout object and sending the data through a SHA algorithm.
Any help/clues are appreciated.
ps: no it doesn't have to be SHA hash, anything close would work too.
-AC
  • drdanmc
    drdanmc over 8 years ago
    Nothing like that that I am aware of but the OA database contains a cellview counter.
    cv = dbOpenCellViewByType("myLib" "myCell" "myView" nil "r")
    cnt = dbGetCellViewCounter(cv)
    printf("Cellview counter is %L\n", cnt)
    this counter is incremented when the layout changes so you can use that.  One catch is this won't tell you if an instantiated cell inside your cell changed.  Only if the top level changed.  So to fully check you'd have to check the counter for each master used in the hierarchy.
    Hope this helps.
    As far as a SHA hash, you could also just use something like:
    openssl sha1 path/to/myLib/myCell/myView/layout.oa
    and if you're in skill, you can find the path to that oa file with
    cvId = ddGetObj("myLib" "myCell" "myView")
    cvId~>readPath
    and
    cvId~>files~>readPath
    again, be careful because that won't tell you if underlying cells changed.
    -Dan
    Andrew Beckett over 8 years ago in reply to drdanmc
    Dan's right. The counter is how various tools normally detect a change in the cellView.
  • acowan
    Thanks. We're testing this now... to make sure the counter changes ONLY if the layout has a real change, and not just because the layout is 'saved' or 'checked into DSM'.
