  3. decrease list of lists by 1 hierarchy list
  • Replies 7
  • Views 17204
Leonardo Vinci
Leonardo Vinci over 8 years ago
i have a list named A in this format:    (  (((x1) (y1))) (((x2)(y2))) (((x3)(y3)))  )
But i have to decrease its listing hierarchy by 1, ie. i want a format like this: ( ((x1)(y1)) ((x2)(y2)) ((x3)(y3)) )
How can i do this?
Leonardo da Vinci
    Andrew Beckett over 8 years ago +1
    You can do this (destructively) by doing: A=foreach(mapcan sublist A sublist) You can do it non-destructively (if each sublist only has a single element) by doing: foreach(mapcar sublist A car(sublist…
    Andrew Beckett over 8 years ago in reply to RK56 +1
    Ramakrishnan, There is a class of functions in SKILL called mapping functions, which iterate over a list (or multiple lists). These can either be used this way: mappingFunction ( existingFunctionAcceptingNargs…
    foreach(mapcar sublist A car(sublist))
  • RK56
    RK56 over 8 years ago in reply to Andrew Beckett
    Andrew,
    Could you please explain your mapcan solution?  I find mapcar easy to implement but mapcan is some how tougher to understand.
    -Ramakrishnan
    Ramakrishnan,
    mappingFunction(existingFunctionAcceptingNargs list1 ... listN)
    Or if the function doesn't exist already, you could create an anonymous function:
    mappingFunction(lambda((arg1 ... argN) ... do something ...) list1 ... listN)
    However, many people are put off by using lambda, so there's a convenience form using foreach:
    foreach(mappingFunction arg list ... code that uses arg ...)
    or for multiple lists:
    foreach(mappingFunction (arg1 ... argN) list1 ... listN ... code that uses arg1 through argN ...)
    Let me start by describing the 6 main mapping functions. The lists used in the examples are:
    l1='(1 2 3 4 5 6)
    l2='(4 3 9 1 7 8)
    Function name Input to existing function Return value Example Return value from example What is printed (if anything)
    mapc each element in turn first original list mapc('println l1) (1 2 3 4 5 6) 1
    2
    3
    4
    5
    6
    map remainder of each list in turn first original list map('println l1) (1 2 3 4 5 6) (1 2 3 4 5 6)
    (2 3 4 5 6)
    (3 4 5 6)
    (4 5 6)
    (5 6)
    (6)
    mapcar each element in turn list of the return values of the function called mapcar('plus l1 l2) (5 5 12 5 12 14)
    maplist remainder of each list in turn list of the return values of the function called maplist('length l1) (6 5 4 3 2 1)
    mapcan each element in turn
    function called needs to return a list; these are all appended
    (efficiently) and returned
    mapcan('list l1 l1) (1 1 2 2 3 3 4
    4 5 5 6 6
    mapcon remainder of each list in turn function called needs to return a list; these are all appended
    mapcon('list l1 l2) ((1 2 3 4 5 6)
    (4 3 9 1 7 8)
    (2 3 4 5 6)
    (3 9 1 7 8)
    (3 4 5 6)
    (9 1 7 8)
    (4 5 6)
    (1 7 8)
    (5 6)
    (7 8)
    (6)
    (8)
    Some of the examples above are a bit artificial, but hopefully you get the idea.
    In this case, we have our input list A='(  (((x1) (y1))) (((x2)(y2))) (((x3)(y3)))  ). When we do:
        println(sublist)
        sublist
    it will print out:
    (((x1) (y1)))
    (((x2) (y2)))
    (((x3) (y3)))
    The return value will be these lists all appended together (as I said, it does this destructively, so it is much more efficient than using append):
    (((x1) (y1)) ((x2) (y2)) ((x3) (y3)))
    By the way, this foreach(mapcan...) example is completely equivalent to:
    A=mapcan(
        lambda((sublist) println(sublist) sublist)
        A
    You can see other examples of using foreach(mapcan ...) using l1 defined above:
    foreach(mapcan elem l1 when(evenp(elem) list(elem**2)))
    This will then append the following lists:
    nil (4) nil (16) nil (36)
    and so return:
    (4 16 36)
    In other words, a list of the squares of the even members of the list.
    Hope that helps?
  • Leonardo Vinci
    Leonardo Vinci over 8 years ago in reply to Andrew Beckett
    Thanks Andrew! :)
  • RK56
    Thanks very much Andrew.  This is awesome. Few questions here
    1. How does mapcan skip the nil while appending in the example of list of squares of even numbers? A regular append function does not skip the nils
    2. I see mapcar and mapcan can be used alternatively, Is there any situation where only one of them is the right candidate?
    -Ramakrishnan
    Ramakrishnan,
    1. append() does "skip" the nils. If you do: append('(1 2 3 4) nil) or append(nil '(1 2 3 4)) then both return (1 2 3 4). What mapcan uses is really closer to nconc() rather than append (because it's destructive - in other words it doesn't copy the second list, and alters the final pointer in the first list to point to the first element of the second), but either way that does affect the useful ability of mapcon to add nothing to the return list if you don't want to.
    2. They are not the same any way. mapcar generates a 1 to 1 list (1 value in the resulting list for each original value in the input list), whereas mapcan generates a 1 to many (including 0) mapping. They can be equivalent in the case where the return value of each operation is a list with a single element - e.g. foreach(mapcar n '(1 2 3 4) n**2) is equivalent to foreach(mapcan n '(1 2 3 4) list(n**2)) but that's not only more verbose but I suspect it's less efficient (I didn't check). So in the case where they are equivalent, mapcar is the right candidate; in any other case, they're not interchangeable, so whichever gives the functionality you want is the right candidate!
  • RK56
    Andrew,
    Understood. Nil is an empty list though it does not appear visually so.  Visually  it looks like an atom.
    append('(1 2 nil 3) '(7 8 9)) will give '(1, 2, nil, 3, 7, 8, 9) but
    append('(1 2 nil 3) nil) will give '(1, 2, nil, 3)
    -Ramakrishnan
